"First post" just finished my 3 point hitch on cub cadet SGT
   / "First post" just finished my 3 point hitch on cub cadet SGT #1
mpowerjw
Cub Cadet 1872
I've been reading posts on TBN for some time now. Thought I would join so I could share my recent build. I only have very basic fab tools so that limited how elaborate I could get, but I'm still very happy with the way it came out. By the way, this is on my cub cadet 1872.
Not sure how many pictures I'm allowed to put.
   / "First post" just finished my 3 point hitch on cub cadet SGT #3
As many as you can if they are of stuff like this! Nice build, by the way. In the third photo it looks like you have an actuator link (disconnected) that will raise/lower the hitch via the rock shaft - will that be connected to a lever?
   / "First post" just finished my 3 point hitch on cub cadet SGT #4
Nice job..I can't wait to see what you can make with more advanced Fab Tools.
It connects to the single lift hydraulic cylinder in the middle of the frame. It lifts the mower deck, the snow plow, and the 3 point
   / "First post" just finished my 3 point hitch on cub cadet SGT #6
Sweet!
   / "First post" just finished my 3 point hitch on cub cadet SGT #7
Good thinking and good work. It looks like you could disconnect the cylinder pushbar from the from the 3-point lift with a pin and just leave it in place when you weren't using the 3-point? That way your lift cylinder could be used for other things. Might need a prop to hold the 3-point up so you could leave an implement on it. Couldn't tell - did you weld ball-ends on the lower links?
Jim
Jim
I was thinking about removing two pins that hold the lift links and just taking them out then make a couple of short chains that will connect to the top link plate to hold the 3pt up when not in use. The factory rock shaft for the cylinder is made in 2 pieces so I can lock the 60" mower deck up and still use the 3pt. Just not the other way around. And yes there are swivel balls on the lower lift arms.
I just don't have space for anything more than hand held tools. Everything was cut with a 4 1/2" angle grinder and drilled with a cordless drill and welded with my Lincoln 220
I had to build this thing to bend the lower arms.
Just put together a combination sleeve hitch / 2" receiver adapter for the 3pt. I will still have to reinforce the 5/8 holes with some heavy washers. Or is that even necessary?
UNUSED JCT 2 PRONG BALE SPEAR (A54757)
UNUSED JCT 2 PRONG...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
