JD auto-connect mowing decks
   / JD auto-connect mowing decks #1
Bob in Ohio
John Deere 755
Hi, this is Bob in Ohio. Been happy with my JD755 for the past 11 years (it was 10 years old when I got it). I'm a full time loafer. I mow 5 acres and keep a 600 foot driveway open in the winter. The 755 is getting a little long in the tooth, so I was looking hard at a JD2320 until I found out that the auto-connect belly mower is not available. What a bummer. Anyone know if it will be a future option?
   / JD auto-connect mowing decks #2
Welcome to TBN. :)
   / JD auto-connect mowing decks #3
Welcome to TBN, Bob...I was at the JD dealership getting oil filters for my 900-hour 4210, and the salesguy listened to my gripes about the huge PIB the 7-Iron MMM for my JD can be to install, and he suggested I get a new one with the auto-connect MMM....I REALLY like the concept, but I was looking at the 3720. Suggest you connect to the John Deere forums here....and once again, welcome.
   / JD auto-connect mowing decks #4
Having just bought a 1023E with the 60D AutoConnect deck... I don't know that it is worth all the hype. It is wicked cool - BUT you need to be PERFECTLY lined up and be on the right type of ground in order for it to work properly. Maybe I haven't had enought practice... Only hooked/unhooked it half a dozen times or so and it takes me a good 10 minutes to get it right
Interesting. Maybe auto-connect is not as cool as I thought. A drive-over deck is a big improvement over my deck which requires jacking up the front end of the tractor. But I was really intrigued by the auto-connect feature. I would be willing to wait a while if I thought JD was going to introduce a 2000 series model that was compatible with the auto-connect deck.
   / JD auto-connect mowing decks #6
I would be very suprised if the next revision of the 2000 series doesn't have the auto connect. But when? That said, The drive over is really easy.
   / JD auto-connect mowing decks #7
Cannot understand why you would have to jack up the front of your tractor to install the deck.
My 60-inch 7-Iron is a huge PIB to install, to get the rear lift links and the PTO shaft installed, you have to back the rear wheels up on blocks about 4-5 inches, then remove the drawbar, and slide under the tractor on your back, between the rear wheels, and hope you have the deck gage wheels blocked up at the exact height you need to install the rear lift link clevis pins. There is VERY little working room underneath.
Then, the front draft arm pivot assembly was designed to fit a tractor without a grille guard. Mine has the guard, so the pivot assembly does not fit into place and rotate as the manual says it will. The handle hits the grill guard mount when both installing and removing the assembly...
The only easy part of installing the MMM is the two draft arms. Everything else is just a headache. Very, very poor design.
   / JD auto-connect mowing decks #8
I am new to the 2520; have disconnected the 62D twice now.
I can disconnect and reconnect it in <5 minutes, easy. There is nothing to it. Connecting the PTO is a little reach, but no problem.
my .02
   / JD auto-connect mowing decks #9
I got a 1026r a little over a month ago with the 60d autoconnect. When it was delivered, my dealer did a great job explaining and demonstrating how to remove and re-attach the deck. I am no tractor expert, but my deck can be removed, re-attached and cutting grass in less than two minutes.
Thanks for all the posts! I went to UTube and watched videos showing how to attach and detach the 62D deck on the JD2320. Wow, it took only about 2 minutes each way. I think the drive-over deck is a big plus and goes a long ways to making the attachment process painless. I'm ready to resume looking at the 2000 series tractors.
Now I am trying to figure out whether to go for a 2720 over a 2320. I like the larger tires and the added horsepower, but don't like the added cost. Guess you get what you pay for.
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2019 FORD F-550(INOPERABLE (A52472)
2019 FORD...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
2022 New Holland T5.120 Tractor with Loader (A51573)
2022 New Holland...
2015 Peterbilt 320 Truck (A51692)
2015 Peterbilt 320...
