Fluid for backhoe with PTO pump?
   / Fluid for backhoe with PTO pump? #1
Ken P
North Granby, CT
Kubota B2410
Folks -
I have a Woods 6500 hoe on my Kubota 2410, it works off a PTO pump. I got it used about a year ago, and I do not know what kind of fluid is in there now.
I need to top off the fluid, and have some SUDT2 on hand. The manual calls for "SAE Hydraulic Transmission Fluid" or "Type "A" or "F" ATF", but sternly warns against mixing oil grades or types. Will the SUDT2 do for now? And, when I fully change the fluid, which of the recommended fluids should I choose, and if I could get a specific brand name to look for, I'd appreciate it.
Thanks - Ken
   / Fluid for backhoe with PTO pump? #2
If you don't know what fluid is in it now, and the manual "sternly warns against mixing oil grades or types", nobody here is going to tell you what fluid to add.
Bite the bullet and do a full fluid change. Choose the fluid from the list of "approved" fluids which are readily available, with some consideration of the cost. The "SAE Hydraulic Transmission Fluid" would be your choice only if your tractor's transmission and your hoe share the same fluid.
   / Fluid for backhoe with PTO pump? #3
If it were me I would use the SUDT2. First, Kubota says it is compatible with all hydraulic/transmisson fluids. Second, most pto pumps are tolerant of a wide range of fluid viscosities. The most critical factor is viscosity at the highest operating temperature of the system, when the fluid is at its thinnest and provides the least protection against metal to metal contact.
Although pump manufacturers have different specifications for minimum viscosity, I think 10 centistokes (cSt) kinematic viscosity is high enough for most. I recall that the KV of SUDT2 at 100deg C is between 9 and 10 cSt. So the SUDT2 you add will have to reach almost the boiling point of water before it thins out enough to provide only marginal lubrication. I have a B2400 and I don't believe it's 18 pto hp can get a few gallons of fluid that hot in a month.
   / Fluid for backhoe with PTO pump? #4
How many gallons of fluid are you talking here? A pail?, maybe 3 or 4 gallons? Not familiar with your hoe, but I think I would consult the builder, identify the oil, and change it out now. Peace of mind and perhaps longer life on equipment will ensue.
   / Fluid for backhoe with PTO pump? #5
Consult the builder? The OP quotes the operator's manual. He even stated the published recommendations in his first post. He can't go wrong by folllowing them. I can't imagine what advise could possible be better.
   / Fluid for backhoe with PTO pump? #6
You have the manual. Drain it and use the recommended fluid per the MANUFACTURER's specs. This way no guessing, no screw-ups.
Case closed. :thumbsup:
CM out.
Thanks for the replies.
I am planning a full fluid change out, but I need to order a filter, so that will have to wait a few days. I was just wondering if a small amount of SUDT mixed with whatever is in there would be ok until then, so I can finish the current digging job.
Brucew44guns and TedLaRue- it'll be 5 1/2 gallons. And, no, this is not shared with the tractor transmission, it is a separate circuit just for the hoe (runs on a rear mounted PTO pump). So, for this, which brand/type fluid would you use (for the full change-out)? I realize there are many choices - which is what gets me confused. It's not entirely clear to me - even after trying to read online - what the difference is between hydraulic transmission fluid and "ATF" which I assume stands for automatic transmission fluid. Is this the same stuff as I would put in my car?
I appreciate the advice. It's helpful to a newbie to have a specific vendor or brand or something to help select amongst the myriad fluid choices, as it's not always clear to me which of the fluids on the shelf match the recommendations in the manual.
Ken
   / Fluid for backhoe with PTO pump? #9
Wouldn't using a different fluid in the BH cross mix with the Hydro in the tractor tranny?
The OP mentioned in his initial post AND a second time that this machine has a separate system powered by a PTO hydraulic pump. :confused2::confused2: Pretty obvious that the BH fluid isn't likely to mix with that in the tractor.:mur::mur:
   / Fluid for backhoe with PTO pump? #10
How can you be down 5 1/2 gallons and still using the hoe?! :confused2::confused:
How many gallon capacity is the entire tank?
If you're down that much and you've been using the hoe I'd say you're likely to do little damage adding whatever you choose...hyd trans fluid, ATF, etc. or possibly cod liver oil or used fry-o-lator oil, or maybe Johnson's Baby Oil. If you value your machine so little as to just guess, then it really doesn't matter anyway. If it were me, I'd wait and get the new filter, change it and the complete oil for the hoe, and THEN finish the digging job.:thumbsup:
   / Fluid for backhoe with PTO pump? #11
I would consider replacing the existing with what you use in the tractor, assuming it is compatible. That is what we did on my dad's pto pump backhoe. One less type of fluid to keep around - or accidently get put into the wrong equipment.
Coyote, sorry for the confusion. The 5 1/2 gallons was in reference to what I was going to need to do a full fluid change (IOW, the capacity is 5.5 gal).
My intent with the original question was to find out if it mattered what fluid I added to top off for the time being. The fluid level was just a little low, it needed maybe a pint or so. I just wasn't sure how much it mattered to mix since I didn't know what was in there.
I was asking because I do value my machine, and even though it seemed unlikely to harm it by adding such a small amount of a different fluid, I thought I'd best ask.
Ken
   / Fluid for backhoe with PTO pump? #13
Ken
OK, got it. If it's only that low, (a pint or so) I'd just use it until the dig is done then change it out completely. I'd warm up the backhoe prior to draining it to have the best flow of gunk and to allow for the max amount of fluid out of the tank.:thumbsup:
   / Fluid for backhoe with PTO pump? #14
if you don't know what's in there.. why not repalce it with some new ut.
i have a woods 6500 hoe. I got it at auction, draine dthe old, good looking oil, and put in new, for piece of mind.
I use dthe 24$ / 5 gallon accell 303 fluid from tractor supply. same oil I use in many seperate sump hyd systems.
soundguy
   / Fluid for backhoe with PTO pump? #15
Sorry my post upset you so much. For one thing, I never have heard of an "SAE Hydraulic Transmission Fluid", or at least heard that label or name put on it, especially by a manufacturer. I assume it means a "tractor hydraulic oil", or "universal tarctor hydraulic fluid", which is usually a 10W/30 viscosity product, whereas a type "A" or type "F" ATF would be closer to an SAE 10 Grade, somewhat different. This pump obviousely is tolerant of various viscosities. I'll mind my own business in the future. I didn't think I advised to go contrary to the operators manual.
   / Fluid for backhoe with PTO pump? #16
SAE: Society of Automotive Engineers.
Don't worry about what others say about your reply. We're all trying to help and learn from each other.:thumbsup:
   / Fluid for backhoe with PTO pump? #17
That would be my guess as well.. IE.. it's calling out a generic multi purpose oil like a UTF fluid.
between that and the ATF oils it specified, I imagine it's hard to go wrong with anything from 10w-30w type base oils.. I'm running a economy UTF in my 6500... accell 303 fluid..
soundguy
CASE TR310 SKID STEER (A60429)
CASE TR310 SKID...
(18) 10'-6" PVC CONDUIT PIPES (A60432)
(18) 10'-6" PVC...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
UNUSED FUTURE PC71-71" HYD PLATE COMPACTOR (A60432)
UNUSED FUTURE...
John Deere 5525 (A60462)
John Deere 5525...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
