Burned up my chop saw
   / Burned up my chop saw #1
porchdog 352
John Deere 970
I used my chop saw for cutting steel for the first time. I put in a cut-off blade and burned up the plastic kerf plate. I had to make a new one out of Aluminum.
   / Burned up my chop saw #3
That looks a lot like a Ryobi mitre saw I have, which is meant for cutting wood trim, not metal.
   / Burned up my chop saw #4
Hey that came out nice. I do have a question I too would like to cut steel and thought that i would buy a used saw at a yard sale to do it with .How does that work? It was built intending to cut wood, I figure the saw does not know what it is cutting. Maybe feed it a little slower is my guess what do you think?
   / Burned up my chop saw #5
I have been using an old Craftsman 10" miter saw as my dedicated cut off saw for years now...and the plastic kerf plate didn't last long on it either. That said, it has worked fine for cutting anything that will fit in it and that includes a 36"X 3" bar of solid round stock that I cut into 3" pieces for a buddys lathe project.....pretty heavy cutting. Threw the breaker more than once and went through several cut off blades but the saw didn't whimper.
   / Burned up my chop saw #6
Hey, in many cases they use the exact same motor to manufacture both units, just the table and clamping setups are changed. That is how they can manufacture affordable tools, by having common shared componants.
   / Burned up my chop saw #7
That's what happens when you choose the wrong tool for the job.
   / Burned up my chop saw #9
As if a 14 inch abrasive wheel doesn't wear out fast enough! I buy them by the case. I've never regretted buying a metal cutting chop saw.
   / Burned up my chop saw #10
I'd love to afford one of the DAKE cold saws..:drool:, but holy cow$$$.
2014 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2014 Top Hat...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
CATERPILLAR 615C MOTOR SCRAPER (A51406)
CATERPILLAR 615C...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
