Is my fuel still good
   / Is my fuel still good #1
Spaznik1973
A friend and I got a semi on a aution about 5 years ago. well time kinda killed it, so I scraped it. But it has about 100 gallons of fuel. It looks yellow and smells some. is it useable? is there anything I can use to make it useable? A friend told me I could use it in my garage heater and not have any issues but sugessted not to use it in my skidsteer. ??? Thanks for the help...
   / Is my fuel still good #2
I would drain a little off of the bottom until you are sure that there is no water from condensation add a good fuel conditioner at about twice the recommended rate and maybe mix it 50/50 with new fuel and it should be okay.
   / Is my fuel still good #3
HEY....I just read this....are you asking about GASOLINE OR DIESEL FUEL????? PLEASE tell us you are talking about DIESEL FUEL as you should NEVER use GASOLINE in a garage heater, at least I have never known of one that is gasoline fueled.
   / Is my fuel still good #4
Just recently I was going to put a 550 tank at my farm and fill with diesel for the Gator, and the tractor. My local Shell dist. told me to only do that if I was going to use the fuel up in a reasonable time, as low sulfer diesel does not store like the older high sulfer diesel fuel was capable of. You may well have older type fuel in the truck. If no water is in it, I can't see any harm in blending it in to newer fuel if------ you are prepared to replace the engine or maybe the whole tractor if something goes wrong!! Just kidding, but life is risky.
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2020 FREIGHTLINER M2 106 BOX TRUCK (A54607)
2020 FREIGHTLINER...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
