Land Pride Quick Hitch QH15 with 3rd party attachments
   / Land Pride Quick Hitch QH15 with 3rd party attachments #1
geewhz01
I bought a land pride quick hitch as most of my attachments are land pride, but my rotary cutter is not land pride. It is a unit by Lowery Manufacturing in Boaz, Al - Clippers -Lowery Manufacturing, Inc.. I'm trying to figure out a way to get the top link to work with either the hook or the floating link on the quick hitch but it won't. Anyone have any suggestions on getting this to attach or will I just have to not use the quick hitch on this.
Andy
   / Land Pride Quick Hitch QH15 with 3rd party attachments #2
Can you unbolt the quick hitch top hook and turn it over so it hooks the rotary cutter top link? I have a Priefert quick hitch and the design is a bit different my quick hitch top hook is fully adjustable and reversible. Some of my attachments require me to hook the top link with the quick hitch hook reversed. Good luck
   / Land Pride Quick Hitch QH15 with 3rd party attachments #3
should work with floating top link, but remove hook for more clearance. Your LP QH does have a adjustable top hook as well
   / Land Pride Quick Hitch QH15 with 3rd party attachments #4
I had similar problems hitching various attachments. My solution was to purchase about 30" of 3/8" proof chain and one chain hook to match. Set the top link to where the quick hitch is close to the top attach point on the implement. Next, pass the chain around the point where the top link connects, and then around the top bolt on the implement and hook to the chain to itself, making a loop connecting the quick hitch to the implement. Then shorten the top link to the point that the chain takes up some tension. Might take some experimenting, but it has worked for me on 4 different attachments. Simple, quick !!
   / Land Pride Quick Hitch QH15 with 3rd party attachments #5
Andy
Andy, You got any pics?
Attached are the pics. Perhaps the top link on the tractor needs to be more forward so that the quick hitch is leaning aware from the tractor some? Or do I just need to by another top link and attach it from the quick hitch to the implement?
The hook there will move as stated here but the gold piece on each side just won't stretch far enough. :(
   / Land Pride Quick Hitch QH15 with 3rd party attachments #8
I have the same hitch on both my tractors. I have to change the tilt and the hook location when I change attachments. I sometimes have to remove the hook and slid it in thru the implement and then pin it in place. Here my arena drag behind the TC40DA.
   / Land Pride Quick Hitch QH15 with 3rd party attachments #9
I also see there are no bushings on the lower pins. They will tighten up your load and keep it from rattling and vibrating. I bought a set of the Landpride bushings for each implement so I don't have to move them around. They come in different lengths from 1 3/8" to 2" if I remember right.
   / Land Pride Quick Hitch QH15 with 3rd party attachments #10
geewhz01, If using floating top link remove top hook. You should have some flex at top hook for unlevel ground. You could also (I see you cutters top brace is weld cross wise on the bushing) Pull top pin out, move bushing/ strap to the top hole and use lower hole for top pin attachment since you QH top hook is adjustable.
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2020 TAKEUCHI TB240 EXCAVATOR (A52705)
2020 TAKEUCHI...
Kubota K7874 18in. Bucket (A52377)
Kubota K7874 18in...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
