Kubota LA 401 FEL Won't go up!
   / Kubota LA 401 FEL Won't go up! #1
Girtski
Kubota B2710
Second post new member here.
I have a B2710HST with an LA401 loader with 4 position valve. Never has my loader bucket raised consistently to the prescribed height. Occasionally it would, but mostly it only went up about 3 feet until recently. It now only raises about 10". I changed the transmission fluid from Super UDT to Super UDT2, changed the spin-on hydraulic filter, cleaned both screens (which were not at all dirty). None of this made any difference in the height. It sounds and feels like it's reached it's limit when I raise the bucket.
If I take the hoses off and put them on the curl/dump side, the bucket raises full travel and lowers fine. I replaced both detents with new kits a couple years ago because they were sticky and rusted. That made no difference at the time.
I've read where the quick-couplers could cause problems so I swapped them from side to side to see if that would make any difference. It did not.
What I did discover when taking out the quick couplers was that the top port in which the coupler screws on the lift side has no holes in it. It's a dead port. I'm wondering if this is normal? If so that would only leave one port for raising and lowering. Since there is no hole for oil travel I suspect this to be normal or the bucket wouldn't work at all. I would love to see a hydraulic schematic showing the fluid flow during lift and drop activity.
Can anybody give me some tips on things to try next? Although not a hydraulic specialist by any means, I am a mechanic by trade and do not understand why I have intermittent operation and now am only limited to 10" of lift.
   / Kubota LA 401 FEL Won't go up! #2
Welcome, I have the same machine.
Did the curl/dump function work when switched?
No..It would work partially one way and fully the other depending on which port I put the hoses on the lift side.
   / Kubota LA 401 FEL Won't go up! #4
I have the loader shop manual but am not very good with hydraulics. There are two kind of valves, a 3 position and a 4 position bucket control. That might explain why you see one port that appears blocked. I would guess from what you've described that the spool is bad for the boom function. Hopefully someone more knowledgeable will chime in.
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2021 BOBCAT T64 R-SERIES SKID STEER (A51246)
2021 BOBCAT T64...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
