Pulse VS Short circuit MIG break test.
   / Pulse VS Short circuit MIG break test. #11
Very good stuff..I am thrilled to see some Pulse talk on here. Although I have trained with it a lot over the years, ( twin pulse more) I have been enjoying a an RE: to Stick Welding. Never knew it could be so cool.. After all. Anyone can lay a perfect bead with Twin Pulse. Not so with Stick. Guess I like it all..
   / Pulse VS Short circuit MIG break test. #12
I definitely like the looks of the pulsed better, and it appears to have penetrated better too.
   / Pulse VS Short circuit MIG break test. #15
What gas mixture are you using when mig pulsing. I called lincoln and they told me I had to use 90/10 argon co2.
   / Pulse VS Short circuit MIG break test. #16
90/10 at least but many use 92/8 and 95/5. Stainless often is 98/2 or a little Helium in there. 90/10 will work fine. Actually, 75/25 will work in a non cometic application. You may get a small amount of spatter if gun angle is not perfect. Fun Stuff...Try it out if you ever get the chance.
Those welds were with 75/25.
All we have at work is the 75/25 and the 100% argon.
The miller chart does say that you can adjust the arc control setting to adjust for different gas mixes.
   / Pulse VS Short circuit MIG break test. #18
Has anyone used a gas mixer. They are expensive, but would cut down on bottles and let you vary percentages to fine tune what you are doing.
   / Pulse VS Short circuit MIG break test. #19
I have a mixer. It works pretty good. It is the Smith version. Needs to be calibrated every other year or so. I find these used for around $150.00. I guess you can save some money if you need several mixes. I use Argon, 75/25, 92/8 and 98/2 so makes sense to have a mixer. Most people wont need it. Thermal Arc is building a new 252 amp Mig ,Tig, Stick combo in New Hampshire that will run spatter free on CO2. Has a Wire Sharpening Circuit, Inductance Control and more on Mig, Hot Start and Arc Force on Stick, Slope and Trigger lock for TIG. Weighs 60#. Based off of the Thermal Dynamics Plasma Inverter technology I am told. This should be a big deal. They say it will be out in November. Cool looking too. I plan to stop and see it at Fab - Tech.
   / Pulse VS Short circuit MIG break test. #20
yomax4 Where are you able to find them used?
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2017 Ford Taurus AWD Sedan (A55853)
2017 Ford Taurus...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
