Create a PTO by "reverse-application" of a PTO-driven hydraulic pump?
   / Create a PTO by "reverse-application" of a PTO-driven hydraulic pump? #13
I've seen those, but wow they take a lot of hydraulic flow. :eek:
17.1 GPM continuous
21.0 GPM intermittent
Those are the max flow ratings. Based on the size of the motor (4.95 cuin/rev = 0.0214 gal/rev) it will take 11.5 gal/min to turn it at 540 rev/min.
If you have lower flow it will turn slower. Or, you can get a smaller volume motor and buy or make a PTO spline adaptor for it. I posted this as an example of what to get to make it easy to assemble a hydraulic PTO.
I've got a Struck Magnatrac that has a 3 PT hitch with hydraulic motor PTO. I didn't want to take the backhoe off to mount it to the rear of the tractor, so I just bolted it on to a skid steer quick attach plate and use it on the front of the tractor. If I remember right, the magnatrac runs abour 8 gpm flow. If this is close to the flow you have you could order the hydraulic motor with PTO spline from Struck as a replacement part. I don't know the size of that motor, but I've run post hole digger, chipper, and brush hog off the front of the magnatrac using the hydraulic PTO with no problem.
   / Create a PTO by "reverse-application" of a PTO-driven hydraulic pump? #14
I see that this place offers round shaft to PTO spline adaptors. They have a 1" round x 1 3/8 spline that should work if you find the right size hydraulic motor with 1" output shaft.
Hub City Inc -
   / Create a PTO by "reverse-application" of a PTO-driven hydraulic pump? #15
I figured I'd post a few pix of the Struck Magnatrac 3 point hitch/hyd PTO attachment I explained above. The unit was basically a flat backed box that I just bolted to a skid steer quick attach plate.
You could buy just the motor from Struck or the whole hitch and do the same. I don't know what Struck would charge for this unit today, but I'll bet it and the SS attach plate would be cheaper than something like this:
Buy Skidsteer Model 80 3 Point Adaptors from the best source – Skid Steer Solutions. We are your #1 choice for Skidsteer Model 80 3 Point Adaptors. Save time and money by shopping online.
And it would be better sized to a tractor with a smaller hydraulic flow (around 8 gpm).
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A57880)
2019 INTERNATIONAL...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
5' MOWER (A52706)
5' MOWER (A52706)
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
