Truck dried tomatoes
   / Truck dried tomatoes #1
nickel plate
CA
2002 New Holland TC40S
I started truck drying tomatoes two years ago and being that this year is a mega bumper crop, thought I should share the process with TBN just in case you too have an over abundance (is there such a thing?) of fruit.
I made four drying boxes, two at 12"x18" and two at 14"x18" that's just the way the 1/4" galvanized wire cloth worked out. The frames and lower legs that promote air circulation are 1"x2" punk wood from the big box store. For saftey sake I rolled the sharp edges of the cloth to avoid skin rips when handling.
My drying tomato of choice is the Roma as it has more flesh and less gelatin and water to evaporate however these larger cherry tomatoes were labeled as Roma-I wonder if someone gets their kicks by switching around the stick labels? Romas or large cherries, cut them into quarters and set them skin down as to not stick to the wire cloth, you can pack them tight but don't make layers as that will hinder the drying process and invite mold. The larger tomatoes are sliced about 3/8"-1/2" thick and placed on edge and leaning on the side boards until they dry up a bit, then you can lay them flat to finish out. These I turn over once or twice a day to aid the drying and also allows the truck to air out the accumulated water vapor.
With truck parked out in the sun with the doors closed and windows up, place newspapers down to catch any slight drainage during the first day or so.
Depending on the heat of your vehicle and in my case it takes about two to three days for the tomatoes to become slightly drier than the solidity of a raisin. Pack them in freezer bags and store in the freezer until needed on that cold winter day....
   / Truck dried tomatoes #2
With truck parked out in the sun, place newspapers down to catch any slight drainage during the first day or so.
Do you put them in the bed or in the cab?
Covered or not? Bugs?
Very interesting sir... Tell me more please.
Be well,
David
Be well,
David
Sorry David, I just re-posted the photos which disappeared on the first attempt.
   / Truck dried tomatoes #4
Any problems withe galvanised material and the Tomatoe acid?:):)
None as of yet-I know there would be a problem with un-coated mild steel so I'll smash a ripe tomato on my galvanized shop can lid and get back on the findings.
Since it is skin down on the cherries and romas and pretty much the upper face of the larger tomatoes are dry sealed when flipped down on their second phase, I have seen no sign of corrosion or ill taste. Come to think of it, the original placement of the smaller tomatoes does slop around a lot of juice but no problems to date and these four flats have dried two seasons of tomatoes.
The process is so easy and benificial I would gladly switch to stainless steel or poly coated mesh if need be.
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
JOHN DEERE 8245R LOT NUMBER 276 (A53084)
JOHN DEERE 8245R...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
