Question about walk behind trenchers
   / Question about walk behind trenchers #1
grsthegreat
Super Star Member
north idaho
Kioti DK45SE hst cab
Ive run alot of walk behind trenchers, but always on fairly smooth ground. I have a project coming up that requires a 200' long trench , 18" deep along a 30% incline hill. Has anyone here ever run a ditch witch style machine parallel to a steep incline like this? I'm afraid it will always try to either tip over or try to head downhill.
I'm not sure if i even want to do this job. Also, its all landscaped out so excavator or hoe is not an option.
Thanks for advice in advance
   / Question about walk behind trenchers #2
Around here when a job like yours needs to be done, it seems like the contractors usually use a tracked walk behind. I would think that they would be way better than the wheeled versions.
Why do they call them walk behind trenchers when you actually walk in front of them? :confused2: ;)
   / Question about walk behind trenchers #3
I doubt if it will tip over but it will be hard to trench a straight line.
Another thing to watch for is cave-ins. The side of the trench will also be 30 degrees. But at 18 inches deep it probably won't be a big consern.
   / Question about walk behind trenchers #4
I've never done it myself but I have been okay throughout walks and it seems like you know what you're doing so you should be alright...if you choose to do the job.
   / Question about walk behind trenchers #5
A walk behind track machine will do much better and faster. I have always had trouble keeping a wheel driven trencher going in a straight line, tend to drive with one wheel when going gets tough.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2009 Yamaha Golf Cart (A52377)
2009 Yamaha Golf...
