where do you check the hydraulic fluid on bx23 2005 model
   / where do you check the hydraulic fluid on bx23 2005 model #11
Do you have any idea if your transmission oil is original ?
Suck some out and report on its appearance ................
   / where do you check the hydraulic fluid on bx23 2005 model #12
but what a pain it will be to put fluid in it. Looks like,
1*I will need a funnel with a tube hook on to it.
1* Don't get one with a rubber hose on it because it will fold over and dump the funnel full of fluid everywhere all over everything and make a real sloppy mess.
Don't you dare ask me how I know:laughing:.
2*A transmission funnel, with a long neck, is your friend.
2*Not if the neck is rubber because the weight of the fluid in the funnel will cause the spout to double over spilling flud all over things.
I learned this the hard way .
It only has 298 hours on it but sometime before the original owner had the 3000 hour service done to the bx23 at the dealer and said it was pretty expensive. But I will check it.
   / where do you check the hydraulic fluid on bx23 2005 model #14
My dipstick is black and on the left side of the oil fill cap which is yellow
Payment Terms (MUST READ) (A50774)
Payment Terms...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
2019 Caterpillars 299D2 XHP SKIDSTEER (A51242)
2019 Caterpillars...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
2012 KENWORTH T800 (A50854)
2012 KENWORTH T800...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
