Implement HP rating and new tractor question
   / Implement HP rating and new tractor question #1
MrWhippy
Gold Member
Maryland
Ford 1710, Ford 5600, NH Workmaster 55
Hey all,
I'm replacing a Ford 1710 with a Workmaster 55. It has suddenly occurred to me that my rotor tiller and mower are rated for 20-40 hp but the new tractor is 47.5 hp at the PTO.
My question is, can I just run them a bit off of 540 speed, and avoid stripping out gearboxes?
   / Implement HP rating and new tractor question #2
I don't believe you would have any trouble running them on the new tractor at 540 RPM, I don't think that you have any worries.
   / Implement HP rating and new tractor question #3
Slip clutch on each?
Nick
   / Implement HP rating and new tractor question #6
Hey all,
You're OK at 540 rpm, but get a slip clutch installed on the pto shaft (tiller end). Here's the setup I used for a small 4ft Yanmar RS1200 rototiller on my Kubota B7510HST. That tiller had no protection (shear pin, slip clutch) when I bought it. I had to use an shaft extender between the slip clutch and the tiller gear box to prevent the clutch from rubbing on the tiller sheet metal. I also used longer lower 3pt hitch arms to get room for the pto shaft, clutch and extension to fit. Fortunately, the arms from my 1964 MF135 diesel tractor worked fine for this job.
DSCF0123 (Small).JPGDSCF0124 (Small).JPGDSCF0125 (Small).JPGDSCF0126 (Small).JPG
   / Implement HP rating and new tractor question #7
Flusher is right about a slip clutch. Not so much to protect the tiller or cutter, but to protect the tractor. If you get a rock caught in the tiller or hit a hidden stump while bush hogging, something has to give. If the shear pin or slip clutch are installed, they will be the things to give. If they aren't there, what gives could be something very expensive inside the tractor.
Good point.
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2007 Volvo VNL Truck Tractor (A53472)
2007 Volvo VNL...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
