Handy Bend vs Swag 20 Ton Press Brake
   / Handy Bend vs Swag 20 Ton Press Brake #1
Luremaker
Ontario
Kubota L3130HST & NH TC18
After reading J_J's reply to another post where J_J linked to the handy bend brake web site. I thought WOW, I want one of those handy bend gadgets for my 20 ton shop press... that was until I found the price of $698. So I did a quick search for press brakes and found another post here on tbn referring to the Swag Press Brake Kit for $149. I say "kit" because it must be assembled and welded together.
I am sure many of you fabricators have large metal brakes but for us small time hobby fabricators a small press brake would be a nice addition to the metal shop.
Handy Bend | Shop Outfitters
20 TON Press Brake DIY Builder Kit
   / Handy Bend vs Swag 20 Ton Press Brake #2
I have not seen that DIY kit before. Very interesting at $149.
3 years ago, I made up my own brake for my 20T HF press, but it was a
bit different. I used a 1" thick plate with a V-groove cut into it for
the die, and the tool was a a 1/2" plate cut to a tapered edge. I did not
have additional retractor springs, as your photo shows, but I DID use
more side supports. I like how the DIY kit has a self-aligning feature. I
would buy it. Sorry, but I can't find any pix.
   / Handy Bend vs Swag 20 Ton Press Brake #3
The handy bend is sweet but would need to make/save me money right off to justify the cost. The swag kit is a decent deal, Northern sells a similar one ready to go for just a little more money if you don't have a welder.
I made one one for around $50 but only 6" width capacity and it won't do thin stuff well because I didn't make a V-block, just 2 hex bars a fixed distance apart. Thus, a swag I would consider if I had it to do again.
   / Handy Bend vs Swag 20 Ton Press Brake #4
I have not seen the "kits" either, very interesting-Thanks for posting about them:thumbsup:
   / Handy Bend vs Swag 20 Ton Press Brake #5
I built an 8" version , it bends 3/8" x 4" plate like butter with a 20 ton jack. I am in the process of making one similar to the swag kit (nice kit BTW)
I didn't have a press so I had to make a small frame, I am now making a large frame like a real press....LOL When I get done I will have a 24" brake like the swag.
Just keep in mind as the brake gets wider your material has to get thinner.
I built the first one to bend brackets for my jeep projects.
I just recently bought a 36" brake from TSC, it works great for light duty bending, my bro just bent some rocker panels for his nissan pickup:)
   / Handy Bend vs Swag 20 Ton Press Brake #6
I built the Swag kit and it works great. No issues or problems at all. I would build/buy one again. Don's use it a lot but it is handy for little projects here and there. Worth the money if you ask me!
It's good to hear from someone who actually purchased the Swag Kit. I think it will be one of the next shop additions.
   / Handy Bend vs Swag 20 Ton Press Brake #9
2nd on the swag kit.
I have one, and it works great. They also have an HD version out now that can bend 1/2" i think. Great product. Welded it up in a few minutes.
   / Handy Bend vs Swag 20 Ton Press Brake #10
Just what I need - Another Project. Thanks guys :laughing::mad::confused2:
CAT Skid Steer (A50322)
CAT Skid Steer...
2014 PETERBILT 386(INOPERABLE) (A52472)
2014 PETERBILT...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
Year: 2020 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 190,820 Plate: Body Type: 2 (A51692)
Year: 2020 Make...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
