BobRip
Elite Member
The Tundra had a much better ride than the Tacoma. Important for my old body.
overseas. GM is an awful company and I'll never buy one of their vehicles.
You do realize with Toyota you are cheerleading for a company that had side stepped or delayed many recalls over the years that led to the deaths of quite a few people. The 5 year delay in recalling the faulty accelerator pedals and floor mats alone caused close to 100 deaths in the U.S. Some entire families were wiped out in crashes. Internal Toyota memos called the limited recall "A win for Toyota..." because they saved 100 million dollars.
Toyota Recall: Internal Document Declares 'Win' After Negotiating Limited Recall, Saving $100 Million In 2007
[Do you remember the Pinto, later model Fords(all models) with cruise control module mounted on the brake master cylinder, ignition switches, etc, etc, etc. Check a Ford truck forum and look into the transmission problems some of those TT 3.5's are having. All manufacturer's have issues and Ford is no better at fessing up than any of the others :ashamed:
What a great bunch of replies. I'm going with the Tundra dbl cab, V8.
Probably the 5.7 V8 but I do own a 2005 CrewMax V4.6 2WD that has pretty good power. I'll have to look into the towing for both.
Is there really much of a mileage difference between the small and large V8 when not towing?
Renthal said:You do realize with Toyota you are cheerleading for a company that had side stepped or delayed many recalls over the years that led to the deaths of quite a few people. The 5 year delay in recalling the faulty accelerator pedals and floor mats alone caused close to 100 deaths in the U.S. Some entire families were wiped out in crashes. Internal Toyota memos called the limited recall "A win for Toyota..." because they saved 100 million dollars.
Toyota executive urged board ‘to come clean’ - Times Online
Here is a video link comparing all the current full size trucks. Watch the bed flex on the Tundra...its comical :laughing:
Durabilty TEST Ford vs Chevy vs Dodge vs Toyota - YouTube
firemech said:Back to the original question, Tundra or Tacoma? I own a marina and haul about 400 boats per year from 14 ft to 26 ft 5 miles to 160 miles and own one of each. I have owned a 1994 Ford F150, 1997 GMC sierra 1500 and a 1999 Dodge 1500 all with V8 power, trailer towing package and automatic transmission. My 2010 4.6 litre Tundra with a trailer towing package and 6 speed automatic beats all of the above hands down! Our 2007 Tacoma with the 4 litre V6 is a great backup and works well at some of our tight launch sites but the Tundra pulls strong has great brakes and sway bars, the extendable mirrors and limited slip rear end work great. Unless you're hauling 10,000 lbs you don't need the 5.7 which is a bear on fuel, but I'm quite happy with the milage of the 4.6. I understand it's built in North America which I can live with unlike GM, Ford and Dodge. Dodge is built in Mexico, the Ford and GM which we in Canada also bailed out then moved the production of their trucks to the US from Oakville and Oshawa Ontario respectively. Good for you Yanks but I still can't stand liars, both of which GM and Ford are in my opinion. Also I have never owned a Ford or Dodge which went an affordable 300,000 miles which all of my Toyotas have.
