JD 820 - 6 volt alternator on a 12 volt tractor?
   / JD 820 - 6 volt alternator on a 12 volt tractor? #31
I had an old JD lawnmower that used a generator similar to the one shown. I rewired it myself. It was also the starter and after the tractor started would switch over to generating DC current. Worked great for 18 years until hydrostatic trans went, then I traded it in for my 455.
JPC
Does anybody know how fast the engine should spin at idle? If I knew that I could figure out how fast the alt is going (and the right size for the pulley).
And does it hurt anything to spin the alt below 400 RPM?
   / JD 820 - 6 volt alternator on a 12 volt tractor? #33
nope.. just won't charge...
soundguy
   / JD 820 - 6 volt alternator on a 12 volt tractor? #35
You might find that the alternator will work better after you get the new indicator bulb. With the broken bulb, the energizer circuit is open and it has to self-energize. That is the reason you need to rev engine to charge.
   / JD 820 - 6 volt alternator on a 12 volt tractor? #36
once it excites, it should stay charging down to 400 rpm though.
in any case.. 3 wire setup is best IMHO..
soundguy
Hyster H225E (A47384)
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
UNUSED WOLVERINE PFF1-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
New Holland C185 (A47477)
New Holland C185...
