Advice on Gravely 1997 14G Professional Garden Tractor
   / Advice on Gravely 1997 14G Professional Garden Tractor #1
WICKSY44
Gravely 14G
I am new to this site and currently have a 1970 Gravely 432 Commerical direct drive. I'm considering purchasing a 1997 gravely 14G but don't know about all its specifics. Is the mower a direct shaft drive or driven by belts? I wanted to use my 40: direct drive off the 432 with it.
Also, I'm looking for a snow cab for the 14G; does anyone know if they made a hard top (metal) model in addition to the soft canvas?
Thanks in advance,
Doug
   / Advice on Gravely 1997 14G Professional Garden Tractor #2
Doug, the 14G is much like the 432. All attachments are shaft driven. The out front mower can be used on the 14G but the shafts are different from one machine to the other. You would need a different long drive shaft, the one under the tractor. A stub shaft that goes through the front axle and a different u-joint assembly that connects to the front adapter. All the things mentioned are expensive.
Roy
   / Advice on Gravely 1997 14G Professional Garden Tractor #3
And that is where the similarity ends. The G series is the culmination of the 800/8000 series. The 400 series is based on the two wheel tractor transmission. The 800/8000/G is a much larger transmission made specifically for 4 wheel tractor use.
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2005 FREIGHTLINER COLUMBIA SLEEPER (A54313)
2005 FREIGHTLINER...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
