Pole Barn size?
   / Pole Barn size? #11
One more suggestion. I researched as you are. I decided to take the laminated posts and separate them. That way I went with 2x6 walls on 24" centers. It only took a couple more studs per 10'. I had to have a footing and foundation but I now have a building. It has taken a couple of real storms that twisted and dropped several barns very close by. It will be much easier to finish the walls and insulate at a later date. Just food for thought.
   / Pole Barn size? #12
I have a insulated 40by80, but only 10' high. I walled off the center 16'by40' for a woodheated work area, with 10by10 doorways in that section that are closed by big tarps. I have sectional doors at each end, and find it usefull to be able to open it all up and drive thru sometimes....especially with a big trailer. There is a lot of thermal mass in large barns. You heat up the cement in the winter and it stays above freezing during the night. Likewise, in the summer, stays fairly cool inside. Whatever size you end up with, you will someday wish it was bigger. [ Heah....same as tractors... :) ] Some of the 'real tall' big barns around here have block or poured walls up three or four feet or so. But I have never been inside them to see how the structure was built. I am not a fan of sliding doors. I like keeping the critters out. Sectional doors for me... I measured, and the bottom of my trusses are 10'10" for clearance for the 10' sectional doors. I have trusses @ 4' centers and a steel roof.....lots of snow up here... :)
   / Pole Barn size? #13
SO what you have isnt even a pole barn. It is just conventional stick framing with a concrete footer and studed walls.
And with all due respect, I personally think finishing a pole barn is easier. Because you still have nailers every 2', they are just run vertical instead of horizontal. AND they are also easier to wire, because you dont have to drill holes and pull wire through all the studs.
And truss choice also becomes a factor. IF you are using 8' OC trusses (which a lot of pole barn trusses are) you want your posts every 8' so the truss is supported DIRECTLY by the post. I dont think I'd want to set 8' or 10' OC trusses on a wall built conventionally. Just my :2cents:
   / Pole Barn size? #14
We are 48x60x16 and use every inch. I would definitely go 16' as another poster mentioned a fifth wheel or motor home or boat needs the extra height to avoid the pucker factor. Our door opening is 15' 8" to the peak and 18' wide. We mounted our sliding doors on the inside which eliminates fighting the snow in the winter here in Northern Michigan. We also have laminated poles with treated on the bottom part and non treated above. After looking at how a Morton Building was put together we copied their method of building the poles. We found the laminated poles don't twist or warp like a solid pole.
   / Pole Barn size? #15
I won't be putting a combine nor anything else that tall in it as far as I can imagine. As far as door layout, I was thinking having double sliding 16' doors on each 40' end of the barn. and a couple entry doors. Would you suggest anything different? Is 16' not necessary? Should I go with 14' double sliding doors or would you place them on the 72' sides of the barn?
In order to save some money right now, I thought I'd forgo insulating the sides and not install a ceiling until sometime later, but I do plan to insulate the entire building eventually and I do plan to put on roof decking, tar paper and a vapor barrier on the roof so that part is taken care of already.
I also intend to have a full ridge vent and 12" vented overhang all around.
Savageayape,
I agree with 14 foot tall at a minimum. Everybody thought I was crazy going that tall on my 40 x 60, till my father-in-law wanted to put his motor home with roof mounted air inside.....
2nd thing - like you, to save money when I built mine, I only put in sliding doors. I wish I had put one normal or slightly larger than normal garage door in mine, off set from the sliders. It really stinks to have to move a (heavy) 16 wide 14 tall slider to get the lawn mower or a four wheeler out. Plus, you can add an opener if you ever get to the point of storing a routinely driven vehicle in the barn. We keep our convertible in our building, and a lot of times I might drive it if I did not have to open the door, pull the car out, get out and close the door, then repeat process when you get back home.....
If you don't want to spend the money to put the door in now, just lay out your sliders and storage arrangement to plan for the garage door, and have the builder rough in the support poles at the correct spot to allow framing, cutting out the metal, and installing a roll up garage door later. I really wish I had done that.
Been there, done that, trying to work arount it now......
   / Pole Barn size? #16
I have a 32'x50' quonset shop building, a 30'x60'x10' hay barn, a 32'x60'x10' truck/camper shed and I'm currently building a 32'x80'x14' that will serve for hay storage as well as tractor and implement parking.
Having two buildings that are 10' tall, I won't ever build another that short. For example, my fifth wheel camper will only fit in the center of my truck shed. (free-span steel truss with more clearance in the middle than at the side walls) In the 10' tall hay barn (wood truss with ceiling joists: same clearance across the width of the building), I can only stack two rolls of hay, but I have the capability of stacking 3 high with my tractors.
Generally, I would say that's it's hard to build a barn too big or too tall.
   / Pole Barn size? #17
Savageayape,
GO BIG!!! I built mine 60x99, and the next year I had to add on 36 more feet to get more stuff in, lol. Put REAL garage doors in. I put inside sliders, and hated them, in the winter they bound up, and it sucks to have to open them, I have now put in real garage doors and openers on all doors. I just hit a few buttons and I have air flow through the shed. I went 12' tall as that is all I need for height, and it makes the building not "look" so big, lol.......
   / Pole Barn size? #18
I have to ask...why 99'. Did you just want to cut a foot of of them last boards or what???:D
   / Pole Barn size? #19
Nope Cleary Builders builds buildings on 9' centers.......
   / Pole Barn size? #20
Cant see how that is benefical to them OR the customers????
The ONLY thing I see them saving money on is concrete and siding. (since siding is 3' and works out in multipuls of 9).
But ALL the 2x4's for wall girts and purlins, all the base boards, all the headers, etc has to be bought in 10' lengths and then a foot hacked off.
I would think a 100' building with posts on 10' centers would have been cheaper??? 2 less posts (one each wall), 1 less section of wall girts (nailers), FAR less labor measuring and cutting 1' off of everything, one less...you get where this is going.
Personally I always try to build in 8 or 12 foot increments. And preferably 12. Because lumber is standard in that size. it is divisible by 4 because plywood and drywall are 4' wide. and it is also divisible by 3 for the siding. Building on 12' intervals seems to net the cheapes square footage. EX: 24x36, 36x48, 48x96, etc.
2023 CATERPILLAR 259D3 SKID STEER (A52707)
2023 CATERPILLAR...
TEST YOUR BID BUTTON! (A52707)
TEST YOUR BID...
2018 Chevrolet Camaro 1LT Coupe (A55853)
2018 Chevrolet...
(APPROX 125) UNUSED TRAFFIC CONES (A57193)
(APPROX 125)...
UNUSED FUTURE CAT 301 EXCAVATOR ATTACHMENT SET (A57193)
UNUSED FUTURE CAT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
