Last date to seed new lawn in Central Ohio?
   / Last date to seed new lawn in Central Ohio? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
This is sort od a dumb question but when do you suppose is the latest I can put down a new lawn of 75% fescue, 10% KY Blue and 20% perennial rye in Central Ohio? It's a perfect seedbed and I'm using a Brillion seeder. It's Sept 27th now and I figure maybe another couple weeks?
I know this is a ballpark answer but any advice would be helpful. My neighbor has been slow putting down hia lawn and now he needs help. Thanks in advance.
   / Last date to seed new lawn in Central Ohio? #2
It's a risk, waiting this late. Normally, planting between August 15th through Labor Day yields the best results. Now, the ground has cooled, the sun is getting lower, days shorter and the time it has to establish itself before the frosts come is limited. Yesterday.
Go, go, go. Time is about up. :)
edit: It seems OSU agrees with me.
http://ohioline.osu.edu/b546/b546_6.html
   / Last date to seed new lawn in Central Ohio? #3
It is risky now, but here's some info for our area. Straight from the horse's mouth. FWIW, I have seeded lawns as late as November with good results. Of course that year I played golf on December 23 in 63 degree weather.
Natural Organic Lawn Care for Ohio
   / Last date to seed new lawn in Central Ohio? #4
Raised in KY, so not too far from ya... Rule of thumb my Granny used (who could stick a stick in the ground and make it grow!), which I still remember, is that for grass seeding any month with an "r" in it, March to November is good. If you get a cold snap in November it might roll it back a bit but what you're planting is a cool-weather grass and it will come right on up. May not grow much in the colder weather, but it will sprout and form roots which is what you're looking for...
   / Last date to seed new lawn in Central Ohio? #5
It's never to late. But you might be better to wait a bit more now and frost seed it or seed it just before frost.
   / Last date to seed new lawn in Central Ohio? #6
6Dogs -
Did you get it in? My wife told me this coming week is an indian summer weatherwise, so it might get rooted...I'm 'kinda' in the same boat.....was supposed to return home on the 18th of October, now just extended till the 24th, and wanted to seed some new ground....think I'm outta luck.
Hope it works for you!
6Dogs -
Well, I had two. One with a fescue/ryegrass blend I put in and, after two weeks of damp weather, it looks great. Other lawn needed too much prep work so it won't be ready in time. I did search this a lot and get a lot of opinions of those who it worked for and didn't. Spoke with a few OSU turf people.
My belief is that you can start one of the newer fescue/ryegeass blend lawns that have the new variety bluegrass (10%) lawns up until maybe late-ish October if you feel lucky. Cutoff for me is going to be maybe October 15th or so.
OK--here's the results from late season planting in a typical to slightly wet/cool year. Grass planted in the mid Sept to end Sept time frame did wonderful and looks like a new lawn should. Planted in the first week of October is still OK but not nearly as thick and lush as earlier grass.
In the second and third week of October my results were not good. Yes, the grass grew just a little bit and really struggled. This may perk up a bit before winter but it's too prone to "washing" in a hard rain or just turning muddy. So, the answer would be to plant grass in central Ohio, or similar location, before the end of the third week of September and at the latest the end of that month. Just my two cents.
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
