2008 L3240
   / 2008 L3240 #1
JoeL3240
I have a 2008 L3240 HST Tractor. The Front Differential case is supposted by the Front Axle Support and the Rear Axle Support. I can not seem to get grease into the Rear Axle Support. I have removed the grease fitting and pumped grease through it so the grease fitting works fine. With the grease fitting off I have removed all the grease from what appears to be a blind hole about 3/8" in diameter by about 5/8" deep. Is there any reason why I can not get grease into this Front Differential Case - Rear Axle Support. The Front Axle support once I remove the air plug takes grease fine.
   / 2008 L3240 #2
I have same problem on my 2009 L3940. I do not understand why Kubota did not put removable plug on rear like they did on front?!? You may want to move this to the Kubota owners and operating forum here. Let me know if you figure it out. Philip.
17604 (A51694)
17604 (A51694)
2023 Toyota Highlander Hybrid SUV (A50324)
2023 Toyota...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
