Loader 1533 FEL Question
   / 1533 FEL Question #1
n92687
Member
N. Fla
Massey 1533
I have a 1533, when I use my FEL, I can only barely pick up 3/4 bucket of dry sand. It seems like the FEL has lost it's ability to pick up it's designed payload. I have added a second valve that allows me to use my small grappler, but I don't think that would have reduced it ability. I only have 130 hours on the tractor. It has not had any work done to it since the 50 hour PM.
I have probably neglected some things, but will go over my manuel when I get back. i need to pay more attention to the maintenance schedule.
Does anybody have any ideas of what to look for? Maybe air in the hydraulics?
I have a box blade that is elevated when I use my fel, does the hydraulics also hold UP the box blade while I use the fel? In other words, am I taxing the hydraulics by driving around with the box blade raised and it draws the needed power to pick up the heavy sand?
Thanks,
John
   / 1533 FEL Question #2
I've never had a problem with ours. Not sure if our 4n1 bucket has a slightly smaller capacity than yours, but I can easily lift a full load of topsoil.
I'd at least check the fluid and make sure it is full.
   / 1533 FEL Question #3
My guess would be either low fluid level or the pressure relief valve needs to be bumped up a little. Maybe the spring was weak to start with. Air will bleed out of the system on it's own with normal use. I am assuming that it would pick up a full bucket before now?
   / 1533 FEL Question
I don't know anything about the hydraulics. How challenging is it to make adjustment to the pressure relief that might allow it to pick up more weight?
I would like to find out from someone other than the shop what I might have to look for to see if I can correct the problem myself. The shop gets 95 an hour for labor. Jezz.
I figure someone on this site really knows the hydraulic system on the 1533
John
   / 1533 FEL Question #5
John
Unfortunately I am not familiar with the system. :eek: I do know that you should use a pressure gauge when adjusting it. You do not want to go much over OEM specs and you should find out what that number is, although I guess that it is around 2500PSI. You may want to get the shop manual for your tractor and loader, but that will be expensive in itself. :( Maybe post the question in the hydraulics section, lots of smart people over there.
And you are right, someone here can help you out. ;)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2025 GIYI GY-X39F Hydraulic Trencher Skid Steer Attachment (A53421)
2025 GIYI GY-X39F...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
