Heating Metal to Release Filler Plug
   / Heating Metal to Release Filler Plug #11
Aluminum grows faster than steel when heated (has a greater CTE). Heat the aluminum and turn the plug while everything's hot.
   / Heating Metal to Release Filler Plug #12
Yeah, but when holes are involved, expansion may not work to one's advantage.
   / Heating Metal to Release Filler Plug #14
I've had good luck removing bolts, and plugs from aluminum with a heat gun, and a spray bottle of water. Find a short piece of pipe that will just fit over the bolt / plug. Heat the aluminum around the bolt / plug real good, hold the short piece of pipe over the bolt / plug and spray water into the pipe. Drop the piece of pipe, and remove the bolt / plug with a wrench.
Tried the wax, hopeful as it appeared it wicked into the treads. No Joy, followed up with more heat, slotting with a grinder, cold chisel, hammer, select profanity, beer and I am going to have to remove the transfer case. Thanks for the help.
   / Heating Metal to Release Filler Plug #16
What about securing a magnet real close to the pug, and drilling it out? Step drill it until you can cave it in with a cold chisel, and retap the threads if necessary.
This all started with driveline noise, I might continue to try and resolve the problem on the Jeep if I didn't think the TC was bad. Should junk the vehicle but it has been my baby for 15 years and can't part with it just yet. :)
   / Heating Metal to Release Filler Plug #18
Sometimes heating is not the way. See if your local welding supply will sell you a little Liquid Nitrogen. Dangerous stuff but if handled carefully it works wonders. Dribble a little on the area that you are having trouble with. It freezes so very cold and everything contracts so much that it often makes bolt removal as easy as the day it was installed. I always drop my bearing races in N2 before installing. Same with shafts. Dip in N2 and the bearings slide right on. Just another way to try.
   / Heating Metal to Release Filler Plug #19
Mig weld a nut onto whats left of the plug.
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
2024 New Holland T8.410 MFWD Tractor (A52748)
2024 New Holland...
378804 (A51572)
378804 (A51572)
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2013 John Deere 824K (A52748)
2013 John Deere...
