So I'm out in the shop
   / So I'm out in the shop #12
Sir Paul! Once again, simple and elegant. Now I can finally fix the missing pin on the fire extinguisher.
Crikey! Those pins look factory made!
Thank you Matt. It's simple enough but I think it's a nice little tip ;)
Thank you my friend. It's always worked for me. Nice hearing from you. :thumbsup:
   / So I'm out in the shop #16
very nice. That vise probably works better then mine....
   / So I'm out in the shop #18
thanks for the tip, allways good to see innovation at it's best
   / So I'm out in the shop #19
I used that technique for a short while, but the reason I say short while I found clamping in the vise was squirmy with two round surfaces so I quickly changed to a pipe nipple with a small shallow groove ground in it for the rod to go into rather than using a socket.
To remove flux from the rod, chuck the rod in a drill and using light to moderate pressure with a pair of pliers pull the rod through the jaws while rotating the rod. One trip and about 10 seconds does it for the most part. Follow up with your favorite method to make it shine. 150 grit sand paper or emery tape is usually good enough for my work.:D
1827 (A51248)
1827 (A51248)
ALLISON TRANSMISSION (A53843)
ALLISON...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2025 CFG Industrial 680 (A50123)
2025 CFG...
Hydraulic 80 mm pin thumb & coupler combo (A52384)
Hydraulic 80 mm...
