Newbie shear pin question
   / Newbie shear pin question #12
All that said, slip clutch seems best (and, still requires the shear pin in place, no?)
slip clutch attaches with a harder pin that is not designed to shear, instead, the clutch should be adjusted to slip.. etc.
soundguy
   / Newbie shear pin question #13
   / Newbie shear pin question #15
We can agree that the slip clutch should be adjusted to slip before the pin (of whatever flavor) shears. But the shear pin should shear before the equipment fails more catastrophically, I would think ...which is why I said there should still be a shear pin in place; it might well be stouter than original specs but should still protect the equipment (my reasoning. But, then, you guys are the experts.)
   / Newbie shear pin question #16
May not be pertinent but back in the old days my dad was a New Holland dealer. The standard square balers had a pretty good size flywheel to smooth out the power requirement when the plunger came on stroke. They had both a shear pin and slip clutch. Getting the flywheel moving when you engage the pto could stall the tractor's engine if not for the slip clutch; however, with all the flywheel momentum, the baler would see major damage if you picked up a rock or something else hard that caught between the shear knives that cut the hay. We sold a lot of shear bolts. Some people tried grade 2 bolts when they ran out of shear bolts and ran into problems when it sheared. Grade 2 is the softest bolt and they tend to smear instead of have a clean break. Then it could be tough to punch out the broken bolt. I suspect that is why the book says to use M6 grade 8.8 metric or 1/4 inch (6.3 mm) grade 5 inch. Installing a slip clutch will protect your tiller just as well as a shear bolt because you don't have the momentum of the baler flywheel. My slipclutch on my LandPride brush cutter gets over used as I clean up the neglected land I bought. If I had to replace a shear bolt every time the slip clutch has slipped I would never have got anything done.
   / Newbie shear pin question #17
if you have a slip clutch, the shear pin should be un-needed.
set the clutch to protect the implement and go.
soundguy
   / Newbie shear pin question #18
I have sheared about 1 pin per year going back hundreds of hours. I have pin in PHD,tiller and r. mower. It's just not a big deal.
   / Newbie shear pin question #19
back when kids would rut up my property riding ATV's on it I would shear pins.. then I put up a fence. no more shearing pins.. plus i have bigger mowers now with slip clutches... no more shearing pins..e tc. :)
soundguy
2019 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A52705)
2019 CATERPILLAR...
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
2003 Komatsu WA250 Articulated Wheel Loader (A53421)
2003 Komatsu WA250...
2015 CATERPILLAR 930K WHEEL LOADER (A51406)
2015 CATERPILLAR...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
