mf 135 not firing
   / mf 135 not firing #11
post back what ya find..
soundguy
   / mf 135 not firing
ok guys im finally back, i"ve been all over this thing, rebuilt carb again, it will start and only idle for about 30 seconds when i give it the throttle it dies, so i have fire now it sounds like its starving for fuel. thanks for all the advice it really helps. Tim
   / mf 135 not firing #13
Clean the fuel tank. When I restored my 1964 MF135 diesel a few years ago, my tank was filthy. Took me two days of shaking that tank with nuts and bolts rattling around loose inside to get that sucker clean enough.
   / mf 135 not firing #14
When I rebuilt the Marvin-Schebler on my 135 I ended up reusing the idle needle, the one with the kit came with a rubberized tip, you'll read a lot of complaints about the kit for that carb. After vacuum checking the carb was tight, ended up moving off factory recommended settings to get it to run right, but I got there.
Sent you a private message with some carb documentation, too large to post here.
   / mf 135 not firing #15
Couldn't put it in a private message either. The documentation is simply a breakdown and recommended repair / overhaul and adjustments for the Marvin Scheber and Zenith carbs. It's available on-line so there are no copyright issues, you could find it yourself if you google the make of your carb.
   / mf 135 not firing #16
either starving or flooding.
what's the exhaust look like?
if you slowly advance the throttle what does it do?
soundguy
   / mf 135 not firing
the exhaust is black and smells rich. when i advance the throttle it spits and sputters then dies, then i have to choke it to start it, also i got it running at idle then i pulled the choke and gave it full throttle and it ran decent for a few seconds then it died. thanks again Tim
   / mf 135 not firing #18
sound slike fuel obstruction and leanness, but having to choke the heck out of it to make it run makes burst of rich soot.
a vacume leak will cause this as well as you have to heavilly enrich to make up for it.
soundguy
   / mf 135 not firing
makes sense because when i first start it after it sits for awhile it idles fine then it either runs out of gas or floods.So maybe its not got enough vacume to pull the fuel up?
   / mf 135 not firing #20
probably not a compression/vacume issue.. but could be a leak..
Pallet of (11) 10 Lug Misc Wheels (A51573)
Pallet of (11) 10...
JOHN DEERE 17P LOT NUMBER 227 (A53084)
JOHN DEERE 17P LOT...
2005 International 4300 Truck, VIN # 1HTMMAAL75H100984 (A51572)
2005 International...
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
City of Buckhannon - Power Curber 5700 (A52384)
City of Buckhannon...
