need coulter retainer clamp for JD 412 plow
   / need coulter retainer clamp for JD 412 plow #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
I was at a plow day last Sat. I lost the front coulter and retaining collar clamp [ John Deere part # D 414 A ] later I found the coulter disc - but could not find the coulter retaining clamp. I need help locating a salvaged replacement part. Who sells vintage plow parts?
   / need coulter retainer clamp for JD 412 plow #2
Don't know about vintage plow parts dealers.
Your JD 412 plow looks a lot like my JD 2-14 plow
Should be pretty easy to weld up a replacement clamp.
BTW: the 3pt hitch on my plow was pretty worn out (wouldn't hold adjustment). So I rebuilt it.
Good luck
My plow is a 3 pt 2 bottom - 14" per bottom also but the model number is 412, yes it is confusing, Thanks for responding, so far my plow has been holding its adjustment, but I will record your revision idea in case I have that problem later. What tractor do you use with your plow?
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
Toro Workman Utility Cart (A51694)
Toro Workman...
SELLICK S80J4E-4PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-4PS...
RIGID TOOLBOX (A52472)
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
