Wheel Horse Died! But how bad??
   / Wheel Horse Died! But how bad?? #1
moored4
Great NorthWest /Southwest Washington
Kubota l245dt, l3540, 8N
What happened? It was foggy yesterday and sunshine today so I thought I would mow the yard one more time before it gets to wet to do here in the pacific northwest. Went up the drive about 20 feet and out comes nothing but WHITE smoke and the motor dies! So What Happened? No odd sound or anything to give me warning. No time to look at it tonight! What are your ideas on what happened? :mad:
   / Wheel Horse Died! But how bad?? #2
Can you pull the plug, look at it & run a quick compression check? Sounds like you had enough oil dumping into the combustion chamber from somewhere to either foul the plug or swamp the engine. That or something ruptured and you lost the seal between crankcase & combustion chamber & compression. The fact that it died so quickly makes me think it's not the head gasket or a valve stem.
UPDATE! :D
I took the motor apart yesterday and found ablown head gasket! Went thru the carb while I had it on the bench and after 15 years it had a little bit of a gumme residue in the bowl! I changed all the filters and also put a shut off valve on the gas tank so I can run the carb dry In the winter. So the grass got mowed today and the mower is ready for next spring. One thing off my winter to do list! :cool2:
   / Wheel Horse Died! But how bad?? #4
Glad (?) to say I was wrong about the head gasket ... Congratulation!
Yea! Me also! I just new that I had a piston bad or something bad. This machine is an old one but Good one. The top of the piston looked brand new and everthing was clean. :)
   / Wheel Horse Died! But how bad?? #6
Everytime I have seen that or heard that, it was gas leaking through to the crankcase. Haven't heard that with a Kohler though.
Happens all the time with a B&S or Techumseh and that is why I always install a shutoff in the fuel line. If one with that problem starts and runs for a minute or two you'll need a new rod at least. That white smoke is the tell tale sign. I always pull the dipstick and check the oil. You'll know by feel and smell whether you have gas in there.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2012 LEEBOY 8515B ASPHALT PAVER (A51406)
2012 LEEBOY 8515B...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
UNUSED WOLVERINE SP-15-84W SNOW PUSHER (A54757)
UNUSED WOLVERINE...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
