Cargo Trailer Converted to Utility trailer
   / Cargo Trailer Converted to Utility trailer #1
coal160
Odon, Indiana 47562
Homemade Terremite TBL, Power King 1614
I have the opportunity to buy a burned up 7x16 cargo trailer for $950 (OBO). The enclosure is burnt to the point of the aluminum shell melting away in places. It has tandem torsion axles on it, that, according to the seller, are unhurt by the fire, along with the tires, wheels, and undercarrage. It is a wells cargo trailer. My question is this: Is it worth converting over to a flat bed/utility type trailer? The origional weight (gross) capacity is 7700#, which is way more than I will ever put on it. In my estimation, it will cost me $400-$500 to deck it, but I would have a very nice torsion axle utility trailer when I am done... Any suggestions or advice?
   / Cargo Trailer Converted to Utility trailer #2
If the deck was burned off I can't see how the rubber in the axles wasn't fried.
For 900, no I would not buy it.
For 200 maybe. At least you could get 150 out of it at the scrapyard if you get it and it's totally trash.
   / Cargo Trailer Converted to Utility trailer #3
by the time you buy the lumber to re-deck it, plus your time in removing the old structure, could get one ready to go for what you would wind up having in this one,
   / Cargo Trailer Converted to Utility trailer #4
Run.
I have been in the trailer business for 20 years and would not touch it. Plus, in my area you can get a new 16 landscape trailer for $1500
Heat and metal don't mix and surely does not mix with torsion axles
Lastly. New a guy who converted a livestock trailer and folded it in half with a old 9N.
Run.
Chris
Okay, with nothing but negative feedback about this, I decided to not go through with it. Thanks to all who gave advice!
   / Cargo Trailer Converted to Utility trailer #6
Rubber? I was under the impression that they used a standard metal torsion bar.
(and yes i would have been in the pass on it camp also)
   / Cargo Trailer Converted to Utility trailer #7
   / Cargo Trailer Converted to Utility trailer #8
All I have seen on trailers is rubber torsion. Could not give me another torsion spring trailer. No weight sharing capabilities leads to way more tire failures. We stopped dealing them in the early 2000's after the troubles we had
Chris
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
