40 mm Ammo can
   / 40 mm Ammo can #21
KEBO, that is a nice looking tool box you have there. I don't have enough room on the fender even if I move the grab handle. I would have to move the warning light too. I think I'll end up u-bolting the box to the bottom cross piece of the ROP and make a cross member that I can bolt the side of the box to. Then I can also use the cross member to hang chains off of. Thanks for the idea though.
Here's one TBNer's way to mount a box (this is on a 790). Take note there is no welding involved in the mounting to the ROPS.
   / 40 mm Ammo can #22
clean setup, though if running down the road I'd get a magnetic plaque to stick on the tool box as it is obscuring it. in fact.. should relocate that plaque uppwards with a bracket off the rops I'd think.. where it is it is useless.. etc.
soundguy
   / 40 mm Ammo can #23
I snuck my 50 CAL in on the FEL bracket.
   / 40 mm Ammo can #24
   / 40 mm Ammo can #26
Yessir.. a 64
SWEEEEET! 64 is a good year!
My carpal tunnel has killed my playing (I was not very good though regardless). I have an old 1972 East German Framus Les Paul clone and a new Taylor 215ce acoustic.
Be well!
David
   / 40 mm Ammo can #27
Whats "ROPS"?
Army Grunt
   / 40 mm Ammo can #28
Whats "ROPS"?
Army Grunt
"ROPS" = Roll Over Protection System :thumbsup:
I would call it a rollbar, but the proper term seems to be ROPS (at least here on TBN) so I try to conform where I can.:D
I thank you for your service. :thumbsup:
I was a SGT 97B in the S2 section (always in the TOC like a REMF) in the ARNG back in 2003-04. I did not deploy. My active duty was USN submarines 1982-1986.
Be well sir,
David
   / 40 mm Ammo can #29
Submariner<-<< that's really cool.
Tks. for the reply. Thats where i mounted my tool box,my thought was I couldn't see back their anyway, its wood with no cover,but its dove tailed:)
Army Grunt
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
Caterpillar Loader Quick Coupler (A55218)
Caterpillar Loader...
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
1967 Ford F100 (A47477)
1967 Ford F100...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
