rear remotes kubota L4310
   / rear remotes kubota L4310 #1
rayclar
prince township , ontario, canada
kubota 4310hstc
Noob here, i was in tsc looking at quick couplers for my 4310 rear remotes and im stuck. i see pioneer standard coupler, poppit coupler?? What kind does mine take, they are a break away connection. Any help would be much appreciated. thanks ray
   / rear remotes kubota L4310 #2
Remove one of the QD's on your tractor and take it with you when shopping.
Hi j j, pulled the rear remote and the only # on the qr was sg parker bruning 9006-001. Does that tell you anything? ray
   / rear remotes kubota L4310 #6
Are you looking to get complete sets as in male and female ends? Are your current remotes OEM from JD? Most OEM rear remotes used on AG type tractors under 100HP are 1/2" AG fittings. If you are just looking for the male end, then more than likely you need a 1/2" male AG quick disconnect fitting. Should only be 6-7 dollars.
Hi mtn i have a oem remotes on a kubota, break away release, just not sure if there is a difference between break away and standard release male ends? thanks any info is appreciated.
   / rear remotes kubota L4310 #8
The std 1/2" male AG ends will be fine. The breakaway part has to do with the female end. ;)
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Yamaha (A55758)
Yamaha (A55758)
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
2020 Big Tex 22GN25T5 30' Gooseneck Trailer, VIN: 16V6X2528L6050344, Tandem Axle, Wood Deck, Bad (A59076)
2020 Big Tex...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
