Where can I find CCM hyd top links?
   / Where can I find CCM hyd top links? #12
I purchased a top-n-tilt from CCM and I had problems with my credit card expiration they shipped me the equipment and invoiced me said just send me a check no big deal. Well it was a big deal to me..I like doing business with someone who actually trusts customers. I was and am so pleased with the top link not sure how good my knuckles would look if I had bought one years ago.
So sounds like maybe a ex employee working on someone else reputation or am I wrong.
   / Where can I find CCM hyd top links? #13
only one is an "Approved Advertiser" to TBN...
   / Where can I find CCM hyd top links? #14
www.haytools.com has your hydraulic top links and TNT applications for your tractor. THe HayDR started bringing in these units into the USA from Italy 5 years before I sold them under under the above mentioned name.
   / Where can I find CCM hyd top links? #15
...have you ever typed something but have no clue as to why... this was one of those moments :p
HayDR, glad to see you supporting TBN :thumbsup:
   / Where can I find CCM hyd top links? #16
So, I assume both parties in this are "approved advertisers?"
Being the owner of a CCM hydro toplink, I wish someone would step up to the plate and clear this whole issue up!
   / Where can I find CCM hyd top links? #17
Carter & Carter Machinery...and is still located at ...Johnson City, TN.....
...There is an open court case relating to a former independent contractor but that should not be discussed on these forums.
The ccmachinery website is not under our controll....
www.haytools.com has your hydraulic top links....The HayDR started bringing in these units into the USA from Italy 5 years before I sold them under under the above mentioned name.
...I wish someone would step up to the plate and clear this whole issue up!
Seems to me (read it as speculating), that they can't talk about it until "whatever" court case is finalized.
   / Where can I find CCM hyd top links? #18
The HayDR is the only Approved Advertiser. Carter & Carter has never been an Approved Advertiser only the HayDR.
There is no gag order you can talk all you want about CCM. I sourced it all and controled it all and still do.
   / Where can I find CCM hyd top links? #19
I called Carter and Carter Machinery and they just got a fresh stock of tnt in and sent me one...very well pleased with it and the parts department was very helpful and knowledgeable of what would work the best for my needs...I have always done business with them and will continue... it is the same owners that it always has been just new parts people but same great service!
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
8" CHANNEL IRON UP TO 25' LONG (A51247)
8" CHANNEL IRON UP...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
1831 (A51247)
1831 (A51247)
2007 GEHL CTL-60 SKID STEER (A51246)
2007 GEHL CTL-60...
