955Lincoln
Gold Member
I'm not sure my new garage panel meets the definition of a sub-panel since it is not being fed from the main house distribution panel.
My existing OH 200A single phase residential service connects to a meter base enclosure which feeds my residence panel with a 200A breaker and will also feed my garageshop panel with another breaker. There is a driven grounding rod system at the residence panel....and I assume I would need a separate driven grounding system at new SQ D Homeline 20 circuit garage/shop panel. Is there a need for a ground wire from the new panel to the meter base enclosure or will the driven ground at the new panel surffice?
I'll let GRS take this one as I'm not an lectrishon. Do you have a "meter main" where the meter and your main 200 amp house breaker and some extra breakers are in the same enclosure? I just don't know if this is the case.
