Need help with 54" blower on 1023e
   / Need help with 54" blower on 1023e #1
RxDoc
Johnstown, PA
John Deere 1023e
Just got a new 54" blower for my 1023e. I am having a problem installing the pto shaft under the tractor. When I have mmm lift all the way up I cannot get the shaft on the pto. It will hit the bar that connects the two draft arms. If I put mmm lift down I can run the shaft over the draft bar and everything connects fine. Is this the only way to get it hooked up?
   / Need help with 54" blower on 1023e #2
I don't think that you can have both mmm and snowblower connected at the same time at least not on the 2305. Why would you keep the mmm for snow removal. I think your better off removing it for winter and keep it away from salt and calcium. jmo.:thumbsup:
   / Need help with 54" blower on 1023e #3
Remove the draft bar.
I have the mower off the tractor it's just the lift kit for it that's giving me the issue. I guess I'll just have to remove the bar connecting the draft arms.
Just to give an update the dealer came out to have a look at it. Basically both draft arms and the bar have to come off. It's not to hard just one extra step when spring comes next year.
   / Need help with 54" blower on 1023e #6
Duh! I've should've known better. :confused2:
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55301)
UNVERFERTH 330 -...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
