DennisFolsom
Gold Member
By my thread title, many of you can probably guess what happened to me today.
My left front tire may have been a little low on pressure to start with. There was a small corner hanging out from the left side of the gravel pile, so I decided to turn while filling the bucket (bad idea:thumbdown
. As I was pushing with the rears, had the front wheels turned a bit too much, and curling the bucket up, the left front tire came unstuck! The beads came off their seats on the rim. The tire was flat, but still on the rim.
I dumped the bucket, and used down pressure to lift the front end. Fortunately, I was close enough to the garage that my extra 50' air hose got to where I needed it. Having had a bit of prior experience mounting tires, I knew I needed a bead expander. I used a ratchet strap around the center of the tire. I had to tighten the strap quite a lot to get that R4 to push out to the sides of the rim. I also used a hammer, pounding in the center of the tread, to help force the sides out.
These days, the only air compressor I have on hand is one that was designed to run a couple of nail guns. It's a bit wimpy in the CFM department for seating an R4 front tire. It was a struggle, but I made it.
Checking my tractor manual, they only call for 12 PSI on the fronts. Actually, I should have looked at the loader manual. It seems like there was something about running more pressure there. My tire says "45 PSI max" on it. The other front tire had 17 in it. I decided to try 20 PSI on both sides for now.
This fracas was mid-afternoon today. The tire is still looking good tonight. I'll check it with a gauge in the morning.
From now on, I intend to keep the front wheels straight ahead when pushing into the gravel pile!
I think a new air compressor just moved up a couple of notches on my "want to buy" list. When I moved a while ago, I parted with my big old shop compressor. I have some air tools that my nailer compressor just won't run. It's time for a compressor. Now the question is how much to I want to pay, and how big a unit will I go for.
