8' flail mower is a tough find
   / 8' flail mower is a tough find #2
Around these parts one will find an occasional 6 foot but usually 16-18 for chopping stalks. Cannot say that I have seen a 8 foot. Good luck in your search
   / 8' flail mower is a tough find #5
Are they as rare in your neck of the woods as mine? I can find plenty of smaller ones and a few 90" offset ones, but 8 footers are almost impossible.
They show up occassionally on eBay.
A Vrismo LP2096 8-ft flail sold for $1500 in July 2010.
Good luck.
   / 8' flail mower is a tough find #6
I had an Alamo 88" but it was a finish flail.
I probably should have been a little less specific on the size (anything around 8' within a few inches) would be great.
Everything around here is 5-7 feet or offset quite a bit.
My 102" is offset almost 2 feet, weighs around 3000lbs and will cut up 4" material. The thing is a monster. I have hit dirt ridges before and the thing acts like a rototiller. :shocked::laughing:
Thats what I'm looking for.
Crazy question: can is cut ordinary 3' tall orchard grass reasonably well?
   / 8' flail mower is a tough find #8
The larger flailmowers will cut down the orchard grass as long as you travel slowly -totally dependent on the thickness of the brush. You may want to raise the mower and mow at a higher position first and then lower the mower gauge to go over it second time.
You will loose a bit of the efficiency of the wind tunnel effect/pressure gradient that creates the excellent suction ability of a flail mowers grass slicers or scoop knives on the first pass but it will knock it all down and be very rough until the second lower pass.
Check on Used Tractors For Sale at TractorHouse.com: John Deere Tractors, used farm tractors and farm equipment, tractors for sale, Case IH, New Holland, Agco, Kubota
IronPlanet - Used Heavy Construction Equipment - Auction - Backhoes Dozers Excavators Farm Tractors - Caterpillar John Deere Case Komatsu for sale
and Auctionsales.ca
You should have zero issues finding a used 8 foot or wider flail mower in good condition.
_________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
   / 8' flail mower is a tough find #9
Don't know, never done it. About the only thing that I have really used it for is cutting 50-100 year old sage brush. I would think that it would do that just fine, but like I said never done it. :(
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
1993 Trail Boss Lowboy Trailer (A52384)
1993 Trail Boss...
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
378491 (A51572)
378491 (A51572)
