Jay4200
- Joined
- Nov 23, 2005
- Messages
- 2,053
- Location
- Hudson/Weare, NH
- Tractor
- L4200GST w/ LA680 & BX2200D w/ LA211
I'm looking to purchase a solar panel to keep by batteries at full charge for a piece of equipment which is stored in a remote location. This piece of machinery has a diesel 12v engine and two batteries. Typically, I'd use a 3amp battery maintainer. The solar panels are not rated in amps, but watts. How many watts do I need to maintain these batteries? In the winter, this panel will be covered with snow, so please take that into consideration. I'm currently thinking about a 15watt panel, but it says that a controller is required. When do I need a controller and why?
You don't need much of anything for a panel. You'll only have to replace the ~50mA-hr that is lost due to self discharge. Assuming 8 hours of average charge per day, you'd need all of about 75mW. So, get the smallest panel that you can find and use it.
A typical 12V-system panel generally produces peak power at 14-17V, and will approach 25V when illuminated at no load. When hard-tied to a battery, the panel will look like a current source, and will force excessive current into the battery. Ultimately, the battery voltage will rise to gassing voltage (where you lose electrolyte) then further where the plates will begin to corrode.
I recently designed a charger that is great for this type of application (search LT3652).
I just did a search, and Battery tender makes a slick solution for $80 that contains a panel and an integrated controller. Buy one of these and be done with it.
5-Watt Solar Panel With Built-in Controller - Solar - Batterytender.com
JayC
