Block Heater Install/freeze plug removal notes
   / Block Heater Install/freeze plug removal notes #1
ksshooter
NE Kansas
New Holland TC30
I thought I would pass along a few notes about the removal of the freeze plug needed to do the block heater install. With a screwdriver sitting on the inside edge of the plug I first tapped the screwdriver with a hammer. Then I got serious and then I punched a hole through the freeze plug...s$%t! I did not think that was supposed to happen. Move to a new spot and tried again...another hole...WTH? So I finally started hitting the edge of the plug which I had stayed away from since I did not want to score the block itself. Before doing that I put a screw in one of the holes and gripped it with a small vicegrip so I would not loose the plug! Hitting the edge worked but it put the plug in the block. While pulling it from the block I managed to hit a hot wire on the alternator twice with another pair of vicegrips I was using to PULL the **** thing through the hole. No damage that I know of, but a word of caution that it might not be a bad idea to disconnect the battery (very hard to reach) or cover the alternator with a heavy plastic tarp or bag to shield it from being touched. It is NOT easy to pull that plug through that hole. I had no idea the plug was as heavy as it was. I thought it would be considerably lighter metal considering how easy I went through it with a screwdriver.
BTW..I did this with the loader on :eek: and that was a poor decision which made life much harder. I would advice taking the loader off first. I did not because I did not want to work with a hot engine and I wanted it installed now! :cool: I thought someone might benefit from my experience. :ashamed:
   / Block Heater Install/freeze plug removal notes #2
You just learned that a screwdriver is closer in functionality to a cold chisel than a punch. A decent diameter punch would have spun the frostplug 90 degrees without poking holes in it or sending it into the water jacket.
   / Block Heater Install/freeze plug removal notes #3
I went through the same thing when I did mine. I was lucky, I stopped before the frostplug went into the engine. I drilled a hole in the plug and screwed a body panel puller into it a pulled it out that way.
If I ever do another it will be with a good sized punch! :thumbsup:
I don't have a body panel puller but the screw did help me NOT lose the plug.:D
APPROX (20) PARTIAL ROLLS OF BARBED WIRE (A58376)
APPROX (20)...
2015 GENIE ZX-135 / 70 ARTICULATING MAN LIFT (A52709)
2015 GENIE ZX-135...
9ft Military Cargo Trailer  Heavy-Duty, Off-Road Ready (A59225)
9ft Military Cargo...
2025 CFG H12R Mini Excavator (A56857)
2025 CFG H12R Mini...
(Est) 2000 CAT E120B Excavator (A59213)
(Est) 2000 CAT...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
