New Holland 914A MMM 3-Point Arm Lift Pin
   / New Holland 914A MMM 3-Point Arm Lift Pin #1
Luremaker
Ontario
Kubota L3130HST & NH TC18
I just purchased a used 914A MMM for my TC18. It came complete with all mounting hardware except the replacement 3-Point Arm Pins (Part # AUB164232). Unfortunately the seller sold the tractor and the pins went with it so I am in need of two replacement pins. Dealer price is over $120 for per pin.
Can someone give me the length of the pins from the outside of the flat bar to the center of the hole for the retaining pin so that I can fabricate my own pins. Or if someone happens to have a pair of pins they would like to sell, please PM me. Any help would be appreciated.
Here is a photo of the right side pin. I found this photo here on TBN in a previous post.
attachment.php
The part I am looking for is #13.
attachment.php
   / New Holland 914A MMM 3-Point Arm Lift Pin #2
Heading out to run a few errands. As soon as I get back, I'll go see if I can get you a measurement.
   / New Holland 914A MMM 3-Point Arm Lift Pin #3
OK..............it appears that the flange is 3/8 thick. The length from the outside of the flange to tip is 3 1/2". The hole, from the outside of the flange to hole center is about 3 1/8" to 3 3/16"
Thanks inspector!
2013 Wilson Stock Trailer, VIN # 1W16532A8D5542433 (A57453)
2013 Wilson Stock...
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
2000 FREIGHTLINER CLASSIC (A58214)
2000 FREIGHTLINER...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
