Jd 3520 or kubota l3420
   / Jd 3520 or kubota l3420 #1
dave1132
Which one is better for a backhoe
Don't have a backhoe would like one that's my delimer to by hoe for my B3030 or buy new tractor to have a little bigger one
   / Jd 3520 or kubota l3420 #5
If I were you I'd be looking at a Kubota L39 TLB if you are requiring a backhoe. You will get (slightly) more power a dig depth as they are designed for one another. Any way you go you will not be disappointed. I've always been a Deere man but Kubota's new stuff is really nice. I would go with a cab with whatever you get, a cab, whether it be a factory or a aftermarket like a Laurin they add a lot of resale value and make it wonderful to use in any condition.
   / Jd 3520 or kubota l3420 #6
mguitas how do you like your wallenstein backhoe?
Wallenstein hoes work well. I think there the only compact backhoe that have a extend-hoe on the gx 920. I haven 't seen any other compact backhoe that does.:thumbsup:
   / Jd 3520 or kubota l3420 #7
I think that the Kubota hoe is tighter to the rear of the tractor so when trailering the rear mast pivot isn't an issue when loading.
I feel the backhoe being tighter to the tractor also means there is less stress put on the tractor.
Thats my thoughts!
   / Jd 3520 or kubota l3420 #8
Personally, I would never buy anything other than green. :D Higher resale value I find as well.
   / Jd 3520 or kubota l3420 #10
John Deere makes an excellent backhoe for their compacts. They make, in my opinion, the best construction grade backhoe on the market, ran them for years, and their compact backhoes are the same quality. Wouldn't by anything else. Sure kubota still makes a good hoe though.
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
