Ford 1900 Diesel Tractor Wont Start
   / Ford 1900 Diesel Tractor Wont Start #1
dlangdado
Ford 1900
A little history im not much of a mechanic but I had to put a freeze plug in this tractor i drove it less than a half a mile after plug come out and it got hot. I put the plug in but had to take the fuel line off to get to it and I think that is my issue. The tractor turns over fine but acts like not getting fuel even though I got it all hooked back up. I looked and its got diesel in it. I took the fuel line back off on the other side of what I would guess is a fuel pump and diesel is coming out but just a little bit at best but I think this fuel pump is gravity flow and don't hook into the motor anywhere. The tractor did not stop on me I turned it off, my question is could I damaged the motor because it got to hot, and how do I make sure all air out of fuel lines. Any suggestions appreciated.
   / Ford 1900 Diesel Tractor Wont Start #2
1, yes, you -MAY- have damaged the engine.. hard to say till you get it started.
2, yes, you likely have air in the lines.
3, crack the lines at the injectors with a wrench, and crank over till fuel bubbles out, then tighten down.. sometimes they bang off with not al the injector bled even.
4, pay attention to what I said about not getting skin anywhere near pressurized fuel or oil lines.. tools only. if you think there is a leak.. look for sprays with a piece of cardboard as a backstop .
5, if this is a straight gear tractor, sve the battery and wear and tear on the poor starter and have someone pull you off. they usually pull off pretty easilly within a few yards sometimes. it spins em way faster than the starter can, and you don't have to let the starter rest a few minutes after a few bleed attempts.
if there is a bleeder on your pump and filter .. use them too.
soundguy
   / Ford 1900 Diesel Tractor Wont Start #3
I had a 1900 and #2 and #3 from Soundguy is the probable solution.
Air in the lines.
Pay attention to #4 as well.
Thanks for your help I got it going was air in the line keeping it from starting
   / Ford 1900 Diesel Tractor Wont Start #5
glad to hear it!
   / Ford 1900 Diesel Tractor Wont Start #6
I'll add one thing to this. Back when I had my 1900 and 2110 Fords it was a real hassle to bleed the fuel lines after I changed the fuel filter. It took a half hour.
So the next time I got ready to change it I waited until the tractor was good and hot from field use. Then I changed the filter in warp speed time and filled the filter cannister with fuel before I put it back on. The change took mere moments. Then I tried to start the tractor. I can't recall if it stumbled or not but it started and ran and I did not have to bleed the lines. It's not supposed to work this way but it did and I repeated it on the other Ford. Just my two cents here.
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
LED Peterbilt Sign (A50324)
LED Peterbilt Sign...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
