Mahindra 3710B backhoe, what Bradco model?
   / Mahindra 3710B backhoe, what Bradco model? #11
We have sold dozens of these backhoes and we do see this occasionally. In fact years ago we were complaining to Jeremy at KMW about the bolt issue when he politely and only with a hint of sarcasm asked if we read the manual. :eek: It was then we noticed the 50 hour bolt change recommendation. The problem is that the bolt will brake, but part of it stays in the hole and the chain is then just grabbing part of the weldment, which tears the weldment.
The good news is that a little care makes this problem go away. Keep the chain lubed and adjusted, and that is easy. Change the bolts occasionally before they break.
The only other issue on the earlier 3710's was a plastic connection in the control valve. They will break if you are a bit heavy handed. We see customers with hundreds of hours with the plastic pieces in good shape, then we get the guy that breaks them every 50 hours...repeatedly. Before anyone takes offense, I'll admit they should not be fragile. All the newer backhoes in the last few years have a different valve setup without the plastic parts.
I think the plastic pieces are about $20-$25 each, something like that, so not real bad. Not a bad idea to have one in your toolbox just in case. They only break on long weekends when your dealer is closed, and if you are in the middle of a critical project right before a rainstorm, that seems to make them break as well. Not saying you will ever need one, but if you do it is an easy fix and not real expensive by tractor standards.
We have sold a couple hundred of the Mahindra/KMW backhoes over the years and they are good solid machines.
Dave, you KNOW (well, maybe) that I've ordered two of those plastic control lever ends from you! ha ha....
I'm still waiting on a good weekend to get the tractor apart....
   / Mahindra 3710B backhoe, what Bradco model? #13
Another problem in this area no one sees is there is nothing to hold cylinder in level position, so chain as it wears will be running at an angle and wearing out quicker. I put a piece of angle across under lug on cylinder to keep it level. I could send a photo with phone to someones phone or e-mail :thumbsup:
   / Mahindra 3710B backhoe, what Bradco model? #14
S78wingrider,
I would like to see the angle iron mod that you speak of. Send a picture to nelsondvance@gmail.com.
Thanks,
Nelson
   / Mahindra 3710B backhoe, what Bradco model? #17
I see Dave beat me to this. I was also forwarded an email you sent earlier. There is no update kit or anything, but you'll likely need to replace that cylinder now. I can't make any promises, but let me do some digging and I'll try and make this as painless as possible... warning that could be a challenge :shocked:
   / Mahindra 3710B backhoe, what Bradco model? #18
I beat you by 5-1/2 years, so yes, I won!
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
Land Honor Skid Steer 3 pt Adapter (A50515)
Land Honor Skid...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
