Do fork adjustments matter?
   / Do fork adjustments matter? #1
FF117
West Central Illinois
Branson 4720h
A set of these forks are up for auction tomorrow. I noticed they only have three notches for side to side adjustment on the forks. I'm wondering how much this matters. Obviously more adjustments would be better, but is it a big deal?
   / Do fork adjustments matter? #2
They should be able top slide all the way to the ends of the bar holding them on. I've never seen any that didn't.
Sometimes I use forks not set in the notches. They still work fine, but may move a little on you if not in a notch.
It wouldn't be that hard to grind in notches if your needed more anyway. If the forks are cheap enough, I would get them anyway.
Thanks. I was wondering about damaging them by using while not in a notch, but I guess its not that big of a deal. I'd just have to deal with them sliding. I didn't think about grinding out another notch. Thanks for the tip.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
ALLIANCE 480/80R42 LOT NUMBER 134 (A53084)
ALLIANCE 480/80R42...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
2017 JOHN DEERE CP690 LOT NUMBER 194 (A53084)
2017 JOHN DEERE...
