Loader ZL-20 Hydraulic Fittings
   / ZL-20 Hydraulic Fittings #1
smince
McDonough, GA
2005 Jinma 254
I'm replacing the loader valve for my ZL-20 loader. I've got all of the hydraulic fittings worked out and am making my own JIC female hoses using reusable ends, up to the point of the hard line connections on the boom. Reading through previous posts I know these are some type of "old style" or "new style" metric male ends on the hard lines. I haven't removed a hose from one yet to determine which style, but I'm assuming "old style" since my Jinma 254 and old POS block-style loader valve are both 2005 year models. I would like to adapt the hard line metric male end to a 3/8" JIC male.
I have probably overlooked it but I couldn't find where anyone has positively identified the type of male metric fitting on the "old" and "new" style hard line ends. The answer is typically "buy the valve upgrade kit that Ranch Hand Supply sells." But, I've already got a nice American-made valve, bulk hose and all the other fittings. Another answer someone came up with was to weld the old hose fitting onto a JIC adapter, which is functional but like my rusted-out factory valve, not very pretty. Discount Hydraulic Hose has a variety of female metric to male JIC adapters, but I'm not sure which one to get. Any insight out there?
   / ZL-20 Hydraulic Fittings #2
The year of your tractor/loader/POS valve doesn't necessarily mean much when it comes to old versus new-style fittings. You have to look at them and match them to the photos on RanchHand Supply's website. Ronald has the fittings you'll need to adapt from the OEM Chinese face-seal fittings to JIC or SAE, I believe. On the page where he has his aftermarket loader valve he also has the pictures of the two different style fittings. After checking them against your hard lines,/hoses, if you have any questions just call Ronald - he's a really helpful guy who will get you set up with what you need.
Thanks, Steve and Rich. The adapters from Ronald look like exactly what I'm after. I'll pull off a hose end and give him a call. Out of curiosity I'd still love to know if it's some sort of standard metric fitting or something proprietary from Jinma.
   / ZL-20 Hydraulic Fittings #5
It is not proprietary from Jinma - it is standard, but standard only in China. Virtually none of the online hydraulic parts suppliers have the Chinese face-seal fittings/adapters in stock. That's why we recommend Ronald, as he has found a source of supply and carries them for all of us.
   / ZL-20 Hydraulic Fittings #7
I got the ends to do the same job from a online store called Discount Hydraulic Hose. I had them ship one end first so I could check it. My tractor is a 2003 Jinma 284 and ZL20 loader it was these ends. Hydraulic Hose Fittings | Komatsu 30° Female Swivel These are the ones I used.
FKOMX-06-18
I sent them pics and thats how we found out what they were. I also changed my cylinders to bigger ones and made up new hoses for that also.
Discount Hydraulic Hose.com
Chris
Chris - I actually ran across those and noticed they looked similar to the "old style" fittings and were metric, but wrote them off because of the proprietary Japanese connection. Thanks much for the tip!
   / ZL-20 Hydraulic Fittings #9
Yep, same here. Its them though. The guys at DHH are good and will get you what you need to set it up properly. Something my local hydraulic shops could not do.
Chris
   / ZL-20 Hydraulic Fittings #10
Chris
The guys at DHH are great but would do better to just give the generic dimensions and then say: "Also Komatsu 30° female swivel". :2cents:
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
UNUSED X-STAR PORTABLE 300 GAL FUEL TANK (A51247)
UNUSED X-STAR...
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
