supertech 10w30 full syn oil
   / supertech 10w30 full syn oil #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
anyone ever had an analysis done right out of the bottle?
I'm in the process of putting my ford 63 4000 gasser back togehter.
just got my head kit in, have cleaned up the valves, got push rods on order..e tc.
valve stems were heavilly gunked up and glued in place, bending my intake pushrods..
I blame this junk the govt has pushed on us as gas.
in any event, I'm changing it oil, even though the oil in it was only a few hours old, i've no doubt contaminated it taking it apart and with the use of various solvents an all.. it's just not a question of do it or not.
In any case, i'm considering using the supertech syn oil on it as a cleanup.
I had previously had 15w50 c rated oil in it, but only had done 1 other change on it since getting it.. menaing lots of gunk was liekly left over from the prev owners lack of maint.
when ifirst got the tracotr I drained what looked like tar out of it.. :(
when she goes back together I'll run her off a temp tank and use heavilly treated fuel and check valve adj.. etc.. and get her running... figure the syn oil should clean her up as well. at 20$ for a 5qt jug, it's not a bank breaker, if it's gonna clean better than 16$ of plain oil..e tc., in case I have to go back in for more work, thus making me dump the oil. didn't want to do that with some valvolene premium blue 5w40 :) at 2x the price.. :) :)
so.. was wondering if anyone had specs on t he oil.. etc.
thanks
   / supertech 10w30 full syn oil #2
No specs but I have heard all SuperTech oil is Warren Oils which is a good oil. I would not hesitate to use it one bit.
My Ex's father is a oil distributor here in Indiana and works throughout Ohio, Kentucky, and Illinois also. His old joke is SAE= Same As Everybody Else. Lot of truth in that. SAE ratings are just that, govt ratings. It meets or exceeds a min standard. It has to be 10 times better than the oils available when that tractor was new.
That said I was always told to never break in a new motor with synthetic. I know that is not the case now days with factory new engines coming with synthetic in most. But a barn rebuild is a different story than a factory new motor.
Chris
yep.. while not a hack n slash job, it's for sure not a machine shop rebuild.
I'm grabbing the oil tonight.
My guess is that even a cheap brand full syn has to be AT LEAST s good as a regualr dino brand that I'd be putting back in anyway.
ie.. full syn walmart oil has to be better than dino walmart oil :)
and I hear it does clean real good...
will see.. :)
i'm only risking 20$ :), and if nothing else.. it could be a flush oil to get rid of metal particles and whatnot.. and run it in.
I'll likely cut the filter apart after an hour of running and see what it looks like.
I usually do that on any tractor new to me.
do a change, then cut the old fitler apart to see what was in it.
in the end.. it has to be better than what it had in 63.. whihg probably is what I draine dout earlier when i got her.. :)
ps.. I've been using supertech and tsc utf for over a decade.. both warren unilube products. never had a lube related hyds failure either.
   / supertech 10w30 full syn oil #5
I've run it for years. It's fine.
But I still think MotorCraft 5w-30 semi-synthetic is just as good. FWIW
5w is getting thin for a 48 yr old engine designed for 30w in the summer and 20w in the winter, when new.. :)
though i don't doubt the motorcraft oil is good. i run 15w40 psd oil in my work f250.. and of course, valvolene premium blue full syn 5w40 in my 2 7.3 PSD's really like that oil.. just costs a bit much for a change on them big engines..
   / supertech 10w30 full syn oil #7
I've spent too much time on BITOG, so now I'm a big fan of diesel oils. I'd think a better oil would be almost any 10W30 conventional diesel oil with a reasonably recent API rating. I'm sure you can find a VOA for supertech syns on BITOG, and in general they are OK but nothing special.
I run conventional rotella in the summer in my gas cars, and often 0W40 in the winter, or whatever synthetic is on sale, diesel or gas, with no issues.
   / supertech 10w30 full syn oil #9
thanks
I'm not sure about the oil specs either, but I have used super tech with no problems. What we use to do with engines that had a lot of hunk is just buy cheap oil and change it like every few days. This will get most of the sludge out.
   / supertech 10w30 full syn oil #10
WM 10w-30 synthetic as worked well for us but have moved to 5w-40 Rotella for use on the place. To clean up the old Ford 300 six engine I had the place in town to use 15w-40 Rotella since the engine is dirty and 30 years old. Diesel class seems to have more detergent from what I read.
I use Sea Foam for the last 50 or so miles to cut the crud and clean the ring groves a little better. Put in 1.5 oz per quart of oil and new oil will look dirty in a short order I find.
To clean up a dirty engine we have had luck changing the filter every hundred miles or so AFTER the first oil change. By changing them COLD the it seems more of the heavy stuff may be trapped inside of the filter.
This is can work out where you have to drive something home but really have no way to do a complete oil change. A gallon ice cream bucket with a lid is awesome in that it will catch the dripping oil and filter and you can put the lid back on to reduce risk of spilling it.
A really dirty filter may have been by passing for years and a filter only change will get a working filter in place again. There are under $5 options at WM, etc that will work fine for this approach.
I am thinking older gas engines when writing this.
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2005 Kaufman Trailers Trailer, VIN # 15XFW53265L001140 (A53421)
2005 Kaufman...
66'' root grapple (A53421)
66'' root grapple...
