Does 4 wheel drive = 4 wheel brakes?
   / Does 4 wheel drive = 4 wheel brakes? #21
Excellent explanation, I hope this puts the question to bed once and for all.
James K0UA
Me too. I kinda get tired of typing it over and over:confused2:
I guess if I was smart enough, I would just use copy and paste:laughing:
Good night to all. Happy T-day and be safe. Going hunting wittle wrabbits tomorrow:licking:
   / Does 4 wheel drive = 4 wheel brakes? #23
James K0UA
Boy, you're an optimist!
   / Does 4 wheel drive = 4 wheel brakes? #24
I'm amazed how many people do not understand how a differential works and it's effects on wheel spin.
Same people that believe cars only have one wheel drive?
Lock the rear differential and apply only one brake.... Then tell me it has no effect on the front.
   / Does 4 wheel drive = 4 wheel brakes? #25
Well it is coming up on the "season of miracles" you know:)
The best way to know if 4WD braking is more effective than 2WD braking is get a really good load in your FEL bucket get up some speed and go down a really steep hill and apply the brakes first in 4WD and note the stopping distance, then do it in 2WD.. the reason I say to do it in 4WD first is because there is a better chance it will actually stop.:)
James K0UA
   / Does 4 wheel drive = 4 wheel brakes? #26
James K0UA
After the 2 WD run they can let us know how the test worked out. Assuming they survive the crash at the bottom of the 2WD run.
   / Does 4 wheel drive = 4 wheel brakes? #27
I believe MissouriThunder can tell you how part of that experiment works.
   / Does 4 wheel drive = 4 wheel brakes? #28
Deutz Fahr has 4 wheel braking in 2 wd or 4 wd. That was one of the reasons I bought a Deutz Fahr. We have hilly ground, pulling heavy loads and stopping is a plus. It has hydraulic braking on each wheel and has a hand valve so it can be switched to 2 rear wheels or all 4. Uses a master cylinder much like auto's. Really nice when you have a load pushing you down hill and knowing you can stop.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2017 DODGE RAM 3500 SERVICE TRUCK (A52472)
2017 DODGE RAM...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
