Gear oil leak on Farmftrac-60
   / Gear oil leak on Farmftrac-60 #1
miniracer26
farmtrac 60
There is a drain plug under the transmission, and in front of it about (about 10 inches or so) is a hole with a cotter pin sticking through it. I noticed gear oil leaking from this. There is no way to remove the cotter pin as it is coming if from the inside. Is this normal?
   / Gear oil leak on Farmftrac-60 #2
What you are lookig at is bell housing for the clutch assembly .The hole in the drain plug is called a weep hole. It is there to let unwanted fluids out . Such as oil.The cotter pinis there to keep the hole from plugging up by moving around when you drive around .The gear oil indicatets a front trans seal leak.
Thank you for the info. Do you happen to have the operators manual? The link that was posted doesn't work.
I was hoping that was what was supposed to be there.
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
20ft Bi-Parting Wrought Iron Gate (A51573)
20ft Bi-Parting...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
RYOBI 18V BRUSHLESS ELECTRIC 20" PUSH MOWRE (A51248)
RYOBI 18V...
Hay Spear for Tractor (A51573)
Hay Spear for...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
