Kubota 9540 or Deere 5101 E or Case 95U?
   / Kubota 9540 or Deere 5101 E or Case 95U? #11
where are you located Andy? i may can give you an even better deal
   / Kubota 9540 or Deere 5101 E or Case 95U? #12
Last year, I was in the same boat. I was looking at the NH, Kubota, and the JD. The JD cab sold me. Nobody else makes a cab that spacious and comfortable. (I'm 6'2" and 230) Plus, the A/C system on the JD is the best. You don't say where you live, but here in the Gulf South, A/C is VERY important. ;)
   / Kubota 9540 or Deere 5101 E or Case 95U? #13
can't say much for either JD or Case for lack of experience with them. but my 8540 is one of the finest machines i've ever owned across the board. if u do go Kub, get hyd shuttle W/HD 12 spd tranny (w/the higher cap 3ph lift option) do get reare ballast of some kind as kub is light on it's feet. good luck
I live in NW Houston, but our property is in Somerville. We definitely need a good AC. The Kubota AC seems to be pretty good, like the Deere.
   / Kubota 9540 or Deere 5101 E or Case 95U? #15
We are looking at this exact same upgrade comparison. One of our creature comfort questions is we do a lot of snowplowing with our tractors and have always had trouble in the past keeping the windows at the back of the cab clear from fog. I have always had to run at least 1 of those cig lighter fans to keep enough air movement on the back window. Do any of your JD or Kubota guys have experience with this, good or bad?
Thanks
Brent
   / Kubota 9540 or Deere 5101 E or Case 95U? #16
Thanks
Brent
This is my first and only cab tractor, so I don't have near the experience that others do. But, after a year of ownership, with more than 200 hours on the clock, I can say that there is absolutely NO problems with the heat/air system on the Deere. And, since we're in a drought, I probably have more hours on the tractor in cold weather than hot.
   / Kubota 9540 or Deere 5101 E or Case 95U? #17
Thanks
Brent
   / Kubota 9540 or Deere 5101 E or Case 95U? #19
I don't have any issues with fogging windows, but you may want to look into Kubota's window heat strips.
E/S
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
