Pat's system but need different stabilizer.
   / Pat's system but need different stabilizer. #11
Other than that, I've been very happy with them and the only reason I took them off is that I got a new implemented and the PTO shaft was just a couple inches too short and I didn't want to buy a new shaft.
There are PTO extenders that fit up to make the Pat's able to be used.
I've never dealt with this company - it is just to show what is available.
I got mine for around $20.
Farm Parts Online
OK guys I followed your advice today and with a hacksaw cut off the end of the main pin that had been mushroomed so much there was no way it was going through the hole.
I then took a big sledge and pounded the pin after spraying it with PB Blaster.
Sure enough out it came! Isn't that a great feeling for any of us when a stuck pin becomes unstuck? :)
I called Pat's and they are sending out a new pin for just the cost of postage. I am very pleased with their customer service. I told them it was my fault but they sent it free anyway.
Thanks to all of you for the help. And yes it was the spreader bar I was referring to not the stabilizer. My fault for not being correct.
Thanks again!
Chuck
Yup, you apparently installed it through a dirty/rusty swivel ball. A 3# sledge and a short piece of 3/4" steel pipe should drive that right back through. Then before re-installing it from the correct side, take a few minutes to clean and lube the inside of the swivel ball
//greg//
Will do Greg. Thanks.
Chuck
   / Pat's system but need different stabilizer. #14
Chuck
Hooray! A happy ending.:)
I have heard nothing but good things about Pat's customer service. However, haven't had to use them yet.
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
2013John Deere 244J (A47477)
2013John Deere...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55218)
2015 Freightliner...
