When lowering 200cx quickly sounds like air leakage
   / When lowering 200cx quickly sounds like air leakage #1
damiang
Member
Bangor PA
2011 John Deere 2520
I am not sure if i heard this noise before or not so i figured i would ask you guys. When I raise the loader and drop it quickly (but not into float) I hear a what sounds like loud air leak just under my right foot inside the coupling hook up. When i drop it slowly i don't hear it. So i can't recall if that air dis pursing noise before or not. So i am wondering if that is normal to hear that or is there something wrong????
   / When lowering 200cx quickly sounds like air leakage #4
The sound you hear is probably cavitation.
Here is what Wiki says.
Cavitation can occur in control valves. If the upstream pressure is just above the vapour pressure, then it is possible that the pressure will drop below the vapour pressure as the fluid flows through the valve. If the pressure recovers after the valve to a pressure that is once again above the vapor pressure, then cavitation will occur
Does it sound like the power steering noise in a car/truck when at the end of travel?
ohhh good... I just haven't used it for some time and when i jumped on it sounded just a bit loud.. Thanks guys
   / When lowering 200cx quickly sounds like air leakage #6
The temp of the fluid could make a difference.
J J .. the noise sounds exactly like a air hose leak or when you let air out of a tire type.
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
