How much fuel per month do you burn in your tractor ?
   / How much fuel per month do you burn in your tractor ? #1
Willl
Elite Member
Northwest, WA
Seems maybe we have a large variance amongst users.
Myself;
Summer months, about 30-35 gallons. Winter, maybe 10.
EDIT; ALL TRACTORS COMBINED....
   / How much fuel per month do you burn in your tractor ? #2
Summer, almost none, Winter 20-40 gal, depends on snowfall and air temperature. I mainly use it for bringing up and moving firewood (colder, more firewood), and plowing the driveway.
   / How much fuel per month do you burn in your tractor ? #3
Winter not much. When spring comes around and we get in the hay field ... about 175 gallons a month.
   / How much fuel per month do you burn in your tractor ? #4
It takes me 2 years to go through a 275 gallon tank.
   / How much fuel per month do you burn in your tractor ? #5
I was using a couple hundred gallons a year, but now with all the project done and just maintenance of roads and pastures, I go thru about 100 gallons per year which fuels one lawnmower, my Kubota RTV 900 and my two tractors.
   / How much fuel per month do you burn in your tractor ? #6
With a Kubota BX, probably 5 to 10 gallons a month.
   / How much fuel per month do you burn in your tractor ? #7
About 100 gallons per year.
Chris
   / How much fuel per month do you burn in your tractor ? #8
Never thought about it. Winter time not much but in the spring/summer/early fall we fill the the skid tank when ever it's gets low, maybe 200 gallons ??? guessing for several tractors! All of our diesel is for farm use so we don't have to break it apart for tax reporting!
   / How much fuel per month do you burn in your tractor ? #9
1000 gal tank gets filled 3 times a year .
   / How much fuel per month do you burn in your tractor ? #10
All the following makes a set up like this
or this feasible
Myself;Summer months, about 30-35 gallons. Winter, maybe 10.
Summer, almost none, Winter 20-40 gal.
Winter not much. When spring comes around about 175 gallons a month.
I was using a couple hundred gallons a year, but now with all the projects done and just maintenance of roads and pastures, I go thru about 100 gallons per year.
About 100 gallons per year. Chris
CATERPILLAR 615C MOTOR SCRAPER (A51406)
CATERPILLAR 615C...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
UNUSED WOLVERINE JMR-22-8.5G 1R RIPPER (A54757)
UNUSED WOLVERINE...
2017 HAMM H10i SMOOTH DRUM ROLLER (A52706)
2017 HAMM H10i...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
